EF-B18C/P72 ECU-VSS
Old Feb 21, 2002 | 06:46 PM
Bnjmn's Avatar
Default EF-B18C/P72 ECU-VSS
Anyone know if the VSS signal from the stock EF CRX cluster will work with the P72 (OBD1 GSR) ECU to activate Vtec? I'm using a '93 LS transmission, so there is a speedometer cable coming from the transmission, not VSS wires.
Are there any tricks to fool the ECU?
Also, does the ECU use the VSS for anything else?
Thanks
Ben
Old Feb 22, 2002 | 05:21 PM
Bnjmn's Avatar
Default Re: EF-B18C/P72 ECU-VSS (Bnjmn)
The VSS from the CRX speedo works with the P72 if anyone cares...
Old Feb 23, 2002 | 09:31 AM
xtrafastcivic's Avatar
if you think about it the jdm sir crx has a vss too so it will work as long as the cable doesn't come out vtec wil come in. yes it will work, this is from experience
f20cmx5
Feb 1, 2011 09:28 PM
gursh d
Dec 26, 2007 03:08 PM
civtegra_hybrid
Aug 6, 2004 11:41 PM
spaceman
Apr 8, 2004 11:30 AM
