idle problems
Old Aug 10, 2005 | 10:00 PM
UNKNOWN_MEMBER's Avatar
Default idle problems
When i give the car gas when it's in neutral, the idle will go up then go down slowly, then go down natraully, then back again then down normal. Here's the thing, everything idles good with the IACV not connected. I already cleaned the IACV also.
Old Aug 11, 2005 | 10:08 AM
Old Aug 11, 2005 | 02:50 PM
eightyHD's Avatar
check the vacuum lines.
either it has a hole in it or something
Old Aug 11, 2005 | 08:55 PM
Default Re: (eightyHD)
nope no holes in lines. Also idle is high, 1k and the idle screw is turned in all the way.
RinzEG6
Nov 24, 2014 12:02 PM
joelmatt89
13
Mar 9, 2009 07:03 AM
turbotime
Oct 24, 2005 12:01 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
