motor rebuild GSR and B16 mix-matching parts for turbo
Old Aug 10, 2005 | 09:02 PM
b20vtec crx's Avatar
Default motor rebuild GSR and B16 mix-matching parts for turbo
alright im going to be re-building a gsr block with a GSR head and i also have the entire bottom end of the b16a(obd0)
my goal is to get as low compression as i can and was wonderring if the 1 1/2 motors i have could make that possible?
"<U>Friends</U>" have told me to get a LS crank and throw it into the GSR block to drop compression. im confused!!!
the reason for low compression because im turbod' and want more boost if possible.
If anyone can give me some pointers on mix matching parts to make an ultimate turbo's bseries motor it would be greatly appreciated!!!
thanks
k.c.
Old Aug 10, 2005 | 09:50 PM
crx4life2002's Avatar
Default Re: motor rebuild GSR and B16 mix-matching parts for turbo (allshowcrx)
for all the trouble I would just slap some 9:1 je's in the c1 block and call it a day
Old Aug 11, 2005 | 10:49 AM
Default Re: motor rebuild GSR and B16 mix-matching parts for turbo (crx4life2002)
thats a possability....wonderring could i use the b16 crank for anythng because the crank that was in the c1 was re-done and im a little wierry with how it was done and who did it.
1999siguy
May 14, 2009 03:06 PM
doug118
May 13, 2009 11:37 PM
b18bc3po
Nov 25, 2008 10:57 AM
junfanclaw
Apr 13, 2005 04:12 PM
JDM92CX
Jun 2, 2003 09:09 AM
