quick question: rod bolts
Old Aug 10, 2005 | 08:16 PM
toEknEEg's Avatar
Default quick question: rod bolts
im rebuilding my motor right now, just put the bearings in, put the crank in, and pistons with new piston rings in.
jdm itr motor: been searching and reading what to torque them down to and people have been mentioning getting ARP rod bolts... all i've read is for LS/VTECs planning on revving past 7000rpms. i took the motor with stock internals to 8700-9000rpms on the racetrack all the time.
do i need new rod bolts?
new setup
98 JDM B18C-R
supertech flat valves
supertech dual valvesprings
supertech titanium retainers
blox stage 2 cams
skunk2 cam gears
buddy club two layer headgasket
arp headstuds
an-r compact header
aem hybrid three inch cold air intake
blox intake manifold
custom 2.5 inch exhaust w/apexi N1 canister
uberdata y0!
currently in the process of building it as you read this... gonna make a post once everything is done
Old Aug 10, 2005 | 08:55 PM
dcb16's Avatar
Default Re: quick question: rod bolts (toEknEEg)
every little bit helps. i'd do it
Old Aug 10, 2005 | 10:34 PM
PURPLETERROR aka BIGMATT's Avatar
Its ok to re use your stock bolts, but arp's are cheap insurance.
Old Aug 11, 2005 | 06:07 AM
toEknEEg's Avatar
Default Re: quick question: rod bolts (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">Its ok to re use your stock bolts, but arp's are cheap insurance.</TD></TR></TABLE>
when reusing them, is it necassary to use the connecting rod bolt stretch gauge if the bolt has basically already been stretched? ie from the factory...
Old Aug 11, 2005 | 07:19 AM
yes, you want to use the gague.
Old Aug 11, 2005 | 10:44 AM
Rocket's Avatar
Use both guage and torque wrench.
Guage alone may get you in trouble. Stretch gauge measures exactly what the name says "stretch." What you are really interested in is fastener pre-load. Those two do not always go hand-in-hand in some instances where the fastener has undergone some permant stretch. e.g. when the fastener has yielded, here reading stretch is like reading stretch on a candy bar.
Old Aug 11, 2005 | 12:56 PM
toEknEEg's Avatar
Default Re: quick question: rod bolts (Rocket)
i've got the 98-01 Acura Integra Helms right in front of me....
how come for the LS and GSR motor it lists the torque specs but then the B18C5 you have to use the stretch method?
just checked my main bearing clearances, they read a little wider then .025mm or .001 inches. the bearings are ACL, should i change them out?
im getting sooooooooo frustrated with this.... helms is just making me more confused....
Old Aug 11, 2005 | 07:10 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toEknEEg &raquo;</TD></TR><TR><TD CLASS="quote">i've got the 98-01 Acura Integra Helms right in front of me....
im getting sooooooooo frustrated with this.... helms is just making me more confused....</TD></TR></TABLE>
because the ITR is all raced developed, there is more stress happening with the higher rpm from the itr, Honda decided to use the stretch method allowing the most/best proper clamping force from the rodbolt's.....
Why didnt you use the color codes on the crank for rod bearings? make sure your useing the right size plastiguage...those acl's should be right on the money..
Old Aug 11, 2005 | 09:57 PM
I'd stick with the correct color oem bearings, especially on an itr
2ndchirp
Jun 20, 2024 01:15 PM
092eg6
Jul 12, 2010 07:39 PM
heretolearnandteach
Sep 28, 2008 06:51 AM
poch915
Aug 16, 2005 01:46 PM
2020ls
Aug 20, 2002 03:38 PM
