GT30R Oil Lines Water Lines
Guys using the Garrett Ball Bearing Turbos, do you ppl run the water lines that cool the bearings in the turbo? I've heard some ppl say it's a waste of time. And some say it's a must. Pls advise!
Who is Mr Robot?
its a must. the ball bearings garrett uses are steel, not ceramic. which means they expand and contract with heat differences. if you do not use the water lines the bearings will preamturely fail and garrett will not warranty the unit.
RUN THEM
RUN THEM
