b16 engine build help!!!!
Old Aug 10, 2005 | 05:51 PM
Wasabithegosu's Avatar
Default b16 engine build help!!!!
does anyone know what the connecting rod bolts need to be torqued down to on the b16?
Old Aug 10, 2005 | 07:02 PM
Runnerdown's Avatar
33 ft lbs
Old Aug 11, 2005 | 06:28 AM
doublejz's Avatar
Default Re: (Runnerdown)
oem? arp?
Old Aug 11, 2005 | 06:30 AM
Default Re: (doublejz)
ARP
Old Aug 11, 2005 | 06:43 AM
doublejz's Avatar
Default Re: (Wasabithegosu)
ARP2000 3/8 Bolts are 48-50ft-lbs. w/ ARP Moly (7/16 Wrench Head)
ARP2000 5/16 Bolts are 26-28ft-lbs. w/ ARP Moly (3/8 Wrench Head)
tighten all of them half the final torque specs first then torque them to the specs. if your not using a bolt stretch gauge make sure you tighten them to the specs. loosen them up and tighten them again. I think ARP's site says to do this 4-5 times.
Old Aug 11, 2005 | 06:52 AM
calicodav's Avatar
Default Re: b16 engine build help!!!! (Wasabithegosu)
Torque specs on the rod bolts is 23 lbs/ft
NorCalHB
Feb 1, 2012 07:01 PM
The Jacko
Aug 12, 2005 08:29 AM
H22coupe
Apr 30, 2004 05:24 PM
H22coupe
Apr 9, 2004 01:44 AM
Louie_EM1
Mar 24, 2004 09:51 PM
