crankshaft pulley
Old Aug 10, 2005 | 05:50 PM
wilkerson05's Avatar
Default crankshaft pulley
how do i get my crankshaft pulley off of my 96 integra b18b1 i need to put a new timing belt on....please reply it will be appreciated...
Old Aug 10, 2005 | 05:52 PM
tegratuner's Avatar
Default Re: crankshaft pulley (wilkerson05)
put it in 5th, get someone to put their foot on the brakes. then either use a huge breaker bar or an impact gun to get the 19mm (i think) while your buddy is pressing the brakes. i couldn't get it with a breaker bar but the impact gun got it when i pressed it on and off fast to crack it. good luck.
Old Aug 10, 2005 | 06:11 PM
Default Re: crankshaft pulley (tegratuner)
does it have to be in 5th gear cause i put it in 1st and the pulley still spins...
Old Aug 11, 2005 | 12:04 AM
carsonR's Avatar
try using this http://buy1.snapon.com/catalog...talog with a big breaker bar
Old Aug 11, 2005 | 02:19 AM
98BlackTeg's Avatar
The tool on the top of this pic is designed to help
Old Aug 11, 2005 | 02:33 AM
anngsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carsonR &raquo;</TD></TR><TR><TD CLASS="quote">try using this http://buy1.snapon.com/catalog...talog with a big breaker bar</TD></TR></TABLE> i have one similar to snap on. where you located?
Old Aug 11, 2005 | 02:35 PM
Sam92Teg's Avatar
Default Re: crankshaft pulley (anngsr)
If you can't get the bolt to budge, take it to a local garage and have them use a big impact on it. Then have them re-torque it to around 120 lb/ft so when you get it back home it won't be hard at all to take off. Sometimes, with alot of age on an engine, the crank pulley bolt can take up to 500 lb/ft to get off, yikes.
Old Aug 12, 2005 | 10:00 AM
carsonR's Avatar
i am in austin texas
Old Aug 12, 2005 | 10:07 AM
Racermech's Avatar
Default Re: crankshaft pulley (carsonR)
you can get that same tool off amazon for $25, jsut make sure you get the right one. They list two and one is smaller than the other
Old Aug 12, 2005 | 11:25 AM
Teggy LS's Avatar
Default Re: crankshaft pulley (Racermech)
you can also jam a long screwdriver up in the flywheel and use a breaker bar with a pipe around that bar and just give it hell
i broke 3 extentions and 2 sockets trying to get that off. i ended up getting a 480ftlb impact gun with a 8 gallon Honda gas powered air compressor to get it off.
good luck
Old Aug 12, 2005 | 02:23 PM
JoizeeAutoXer's Avatar
Default Re: crankshaft pulley (Teggy LS)
5th gear with foot on brakes with a 4' cheater pipe on the wrench did not get this ****** off for me, the car actually starter to MOVE. friend's 500-600lb impact didn't budge it either. i went to a mech, he wanted at least $25 cause he said it would have to go on a lift lol BS! another mech i went to didn't even wanna loosen it for me, his reasoning: "if i loosen it and torque it to 130lb again (by spec) it's gonna seize by the time u get home, and i can't hand tighten it for u either because it's illegal to let u drive off with a car that's not assembled properly" BS!!!
so i took it to another mech and for $10 he took it off with his impact in like &lt;10secs without using a lift lol. so guess which mech i went to when i had seized rear LCA bolts...u got it.
natebaur
May 9, 2009 05:09 PM
progoon
Aug 28, 2006 04:56 PM
FOMULA91
12
Jun 1, 2006 02:46 AM
Team 4R
Jan 2, 2004 11:38 AM
94civicx
11
Jan 15, 2002 10:56 AM
