Cam gear question Help!!!!
Old Aug 10, 2005 | 05:14 PM
eortizr's Avatar
Default Cam gear question Help!!!!
I just bought a new adjustable cam gear... but when I compare the new one with the stock one... the new one has 40 tooth and the stock 38... is that ok.... or maybe I have the wrong cam for my civic D series...? the brand is 'Volution Racing'
Old Aug 10, 2005 | 05:15 PM
JDM-97CX's Avatar
Default Re: Cam gear question Help!!!! (eortizr)
Is the new one bigger around?
Old Aug 10, 2005 | 05:19 PM
eortizr's Avatar
Yes it is
Old Aug 10, 2005 | 05:20 PM
JDM-97CX's Avatar
Default Re: (eortizr)
Then I would think it is fine. If it is the same size it doesn't change the ratio of 2:1 between the cam and crank.
EDIT: I can't read and I thought I asked if they were the same size not if one was bigger.
on me for that one.
Old Aug 10, 2005 | 05:24 PM
eortizr's Avatar
So is ok that the new cam is bigger in ration...? and alos 2 more tooth...?
Old Aug 10, 2005 | 05:26 PM
Padawan's Avatar
Darth ModerVader
No, it's not okay. Assuming you had the correct original sprocket on your motor, you were sent the wrong part. Return it and buy the proper sprocket for you application.
JDM-97CX's Avatar
Oh, wait...no, I read that completely wrong. I don't think it is OK that the new gear is bigger. I'm thinking that you got the wrong one.
<----Tired from working too much and needs a vacation but doesn't get one until easter.
Old Aug 10, 2005 | 05:31 PM
eortizr's Avatar
Ok... just to be sure... there is no way that a bigger sproket with more tooths is gonna work properly in my car... cuz I have to argue that with the vendor since he does not want to exchange the part.. cuz he sais the sproket is for civic D-Serie
Old Aug 10, 2005 | 06:15 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eortizr &raquo;</TD></TR><TR><TD CLASS="quote">Ok... just to be sure... there is no way that a bigger sproket with more tooths is gonna work properly in my car... cuz I have to argue that with the vendor since he does not want to exchange the part.. cuz he sais the sproket is for civic D-Serie</TD></TR></TABLE>
sure put it on....then you can sue them for sending you wrong part....when your engine goes BOOM
Old Aug 11, 2005 | 05:13 AM
eortizr's Avatar
any other opinion?
chope045
Oct 30, 2011 04:59 PM
wrx-killer-Sti-eater
Nov 23, 2007 03:56 PM
Soccerking3000
Dec 30, 2004 07:08 AM
Mr_Bojangles
Apr 15, 2004 06:15 PM
brent_G
Oct 24, 2003 02:39 PM
