how do u install msd coil?
Old Feb 21, 2002 | 05:58 PM
jdm_ef9's Avatar
Default how do u install msd coil?
how do you hook up a msd external coil w/ modified dist. cap on a zc?
Old Feb 22, 2002 | 01:12 PM
Urban Business
Guest
Posts: n/a
Default Re: how do u install msd coil? (orangeEF)
take out your old coil from dist. new external coil comes with a wire (looks like a plug wire, kinda) connect coil to the terminal on cap (usually red)
Old Feb 24, 2002 | 05:17 PM
jdm_ef9's Avatar
Default Re: how do u install msd coil? (TorteX)
im kinda confused-- on the new external coil there is a spot for two wires a pos, and a neg. what do i connect these to on my dist?
Old Feb 24, 2002 | 05:23 PM
ViperRedCRX's Avatar
take the positive from your factory coil to the positive of the msd coil, and th same with the negative
Old Feb 24, 2002 | 05:40 PM
jdm_ef9's Avatar
Default Re: how do u install msd coil? (d16crxdxr)
how do you tell which one is which? thank you for the replies!!
Old Feb 24, 2002 | 06:30 PM
Hayasa15's Avatar
wht/blu = negative
blk/yel = positive
anyone want to double check that for me? that is from memory.
Old Feb 24, 2002 | 08:17 PM
AbaZ's Avatar
Default Re: how do u install msd coil? (Hayasa15)
wht/blu = negative
blk/yel = positive
I belive that is right.. the positve wire has 2 leads going to it.. its black/yellow.. and the other is negitive.. I think it even says on the coil itself.
Just extend those wires out to the external coil, install the new cap and your good to go.
Jeff
Old Feb 24, 2002 | 09:57 PM
Default Re: how do u install msd coil? (AbaZ)
the coil has + and - signs on it where the wires go...just use the labeled one in the right place, but the other two guys were right on the colors
Junaid K
Mar 22, 2014 10:26 PM
pv2dickman
Feb 11, 2009 08:16 PM
honda_SiRII94
Apr 9, 2007 08:14 AM
Jonny Rocket
18
Jan 11, 2007 02:37 PM
xci_ed6
Oct 14, 2003 08:42 AM
