blowing blue smoke(oil?)
I went to get gas today, and when i went to start up my car i noticed a couple seconds after idling that there was blue smoke coming out of my exhaust. A couple seconds later it went away. I drove around a lil, did a pull 1st-3rd and didnt see anything(at least i dont think i did?). I pull into my driveway and stop, and see smoke rising up from the rear. I rev the motor a couple times and still smokes.
Someone please tell me whats going on...I plan on doing a compression test later...I would just like some answers now.
Tell us compression and leak-down #s and w will be able to help better, but it could be anything from leaky valve stem seal, cracked ringlands, bad rings, or turbo seals. Only testing will tell for sure. What is your current vacuum system? (catch can, breathers, pcv)
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">Might be your Oil return is kinked, check that, my old Drag kit when I first installed it did it alot cuz it wasnt the best done. Check that out first then compression test</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X »</TD></TR><TR><TD CLASS="quote">I hope its something as simple as a kink in the return line</TD></TR></TABLE>If you want to stop by my place tomorrow, we will check it out. We are trying to get my motor dropped in sooooo......
Also we are doing my oil return line tomorrow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">If you want to stop by my place tomorrow, we will check it out. We are trying to get my motor dropped in sooooo......
Also we are doing my oil return line tomorrow </TD></TR></TABLE>
thanks for the offer, but it hasnt been smoking for a couple days now, wierd. I wonder what it was. I might stop by anyways to say whats up.
Also we are doing my oil return line tomorrow </TD></TR></TABLE>thanks for the offer, but it hasnt been smoking for a couple days now, wierd. I wonder what it was. I might stop by anyways to say whats up.
andystart
14
Oct 15, 2004 08:52 AM
tianporn
10
Jul 20, 2004 11:24 AM
