Need some egine and advice
Old Aug 10, 2005 | 01:05 PM
Ryan.'s Avatar
Default Need some egine and advice
Hey I'm new to this part of the forum. I don't know much about EF's, but there is an 89' Honda Civic sedan forsale down the street from me. I want to pick it up for a DD for the winter so I can garage my EM1.
Bad Things
-Rust
-Engine burns oil and smokes
-I want to swap a jdm d15b into this car so I have a fresh motor for the winter. Want all do I need for this swap? I know I need the tranny and motor. But do I need a new wiring harness,ecu and all that good stuff also?
Thanks in advance.
Old Aug 10, 2005 | 01:08 PM
CRX Toad's Avatar
Default Re: Need some egine and advice (R_star)
Welcome to the forum...I don't know much about that swap but I know that it is done quite often in these here parts.
Old Aug 10, 2005 | 01:13 PM
Ryan.'s Avatar
Default Re: Need some egine and advice (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Welcome to the forum...I don't know much about that swap but I know that it is done quite often in these here parts. </TD></TR></TABLE>
Thanks. I don't need this exact engine but it looks to be a good swap to do. Like I said before I own and EM1 and I personally have never worked on an EF or a single cam. I am just looking for some info on this swap and other possibilities and parts I will need before I make this purchase. Thanks
Old Aug 10, 2005 | 01:25 PM
Ryan.'s Avatar
Has nobody attempted this swap or no nothing of it? All I am looking for is some good info. thanks
Old Aug 10, 2005 | 01:48 PM
cbp_crx's Avatar
you will need engine, you can use the tranny thats in the car along with the axles, it will drop right in, if your car is dpfi, you will need to convert to mpfi, also does that engine have vtec, if so you will need to wire that up, for wiring i recomend going to rywire.com he is droppedcrxsi, on here, and he does a great job, and also many other people will recomend him
Old Aug 10, 2005 | 01:51 PM
cbp_crx's Avatar
also im not real sure on what ecus will work but i believe a p08 ecu is the one that is for the engine someone correct me if im wrong
Old Aug 10, 2005 | 10:39 PM
Ryan.'s Avatar
Default Re: Need some egine and advice (crx_si6)
Thanks for the good info! I just need this thing to be reliable during the winter season.
Old Aug 11, 2005 | 05:25 PM
Ryan.'s Avatar
nobody else?
Old Aug 11, 2005 | 06:21 PM
Ryan.'s Avatar
common EFer's
Old Aug 11, 2005 | 06:30 PM
Ryan.'s Avatar
I might be picking this car up tomorrow so any advice/info would be greatly appreciated.(sp?)
Old Aug 11, 2005 | 06:32 PM
Bjorn20's Avatar
um... for the swap itself it should just be a direct bolt on, as for the rest i have no idea (shift linkage, tranny, all that good stuff), im not a fan of d series, im a b series guy
like what was previosly said, u will need a mpfi harnes if ur running dpfi, im guessing its vtec so more wiring, but not that difficult
Old Aug 12, 2005 | 10:00 AM
Ryan.'s Avatar
Default Re: Need some egine and advice (Bjorn20)
up
Old Aug 12, 2005 | 01:05 PM
Ryan.'s Avatar
again....up
what ecu should i run with that setup? and po2?
Old Aug 12, 2005 | 02:00 PM
VegasEFHB's Avatar
First off, what motor is in it? If it is already a D-series, find a good condition USDM used motor in the marketplace and just drop the beast in there (reccomend the good old base model D15B2, it hasn't failed me yet with DD duties), maybe $100-$200 based on the quality of the motor. If the existing block is DPFI, go with the D15B2 and just leave the intake manifold with the car, it is a direct bolt on, no major work. If you are doing the DPFI-MPFI or vice versa, just be prepared to spend a little more money and time as the ease of transition is similar, but you will need to find an appropriate intake manifold and TB (I reccomend the 89-91 D16 Si intake setup for ease of transition, low cost, and direct bolt on capability; just be prepared to rewire the beast).
Old Aug 12, 2005 | 05:58 PM
Ryan.'s Avatar
Default Re: Need some egine and advice (VegasEFHB)
^^ I am not exactly sure what motor is currently in the car. It is the stock motor , so whatever came stock in a 1988 Honda Civic Sedan. I am not looking for anything fast or powerful. Just enough to get me around during the winter season. So the USDM D15B2 is a direct bolt in swap. I can run the existing ECU with this motor?
Old Aug 12, 2005 | 06:06 PM
. M i c h a e l's Avatar
dotmichael to you
alright the jdm d15b vtec and usdm d15b2 are two entirely different motors. first off figure out which one you want. the d15b2 is whats in that car already..so just get the car and find another motor to swap right in for winter dd duty. you can pick up that motor for anywhere between 50-200 bucks.
if you want a little more power, just convert to mpfi and get a si d16a6 or single/dual cam zc and run that for cheaper than d15b vtec.
what part of pa you from?
Old Aug 12, 2005 | 06:18 PM
VegasEFHB's Avatar
Default Re: Need some egine and advice (.MichaeL)
what .MichaeL said
fyi... I am doing the same thing you are, I just purchased a used USDM D15B2 for $100 delivered to my front door. I will be rebuilding it and swapping it into my hatch, but you can find them really cheap in pretty good condition. Just keep the DPFI and swap that beast into the sedan, man! This would be a perfect time to get a new clutch and all that other garbage, keep that winter DD in good condition before winter starts.
Modified by VegasEFHB at 7:39 PM 8/12/2005
Old Aug 12, 2005 | 06:32 PM
Ryan.'s Avatar
I am just outside of KOP if you know where that it. I am prolly about an hour south of you.
tensecpass
Jan 12, 2008 11:39 PM
fuctupride
May 29, 2006 07:39 PM
zephon96
Jan 6, 2005 08:03 PM
jay.dee.em1
Sep 30, 2004 08:38 AM
tyflip2
Nov 27, 2003 01:07 PM
