trying to find out cel
Old Aug 10, 2005 | 10:02 AM
Eightfuns's Avatar
Default trying to find out cel
k i did a quick search but didnt find anything. my buddy just bought an 88 crx and his engine light came on, what i need to know is where is the plug located and how do you jump it to get the engine code. thanks alot.
Old Aug 10, 2005 | 10:05 AM
hondaboy4life's Avatar
Default Re: trying to find out cel (Eightfuns)
someone correct me if im wrong, but if u pull back the carpet near the passengers feet like pull it down, u should be able to see the ecu, and on it there will be a red flashing light, but in order to make it flash u need to turn the key to the position just before the position that starts the car, so that all the lights on ur instrument thing light up, then go and check the code, if u search on FAQ threads u should find out info on the codes, good luck.
Old Aug 10, 2005 | 10:09 AM
Eightfuns's Avatar
Default Re: trying to find out cel (hondaboy4life)
hey thanks alot i did more of a search after i posted this and found a couple things but this was by far more helpful......hey and thanks for not bein a dick about me posting a common question like this.
Old Aug 10, 2005 | 10:10 AM
BoostdRex's Avatar
Yes that is correct for a factory ECU. There are no plugs to jump unless it's an OBD1 ECU.
Old Aug 10, 2005 | 10:34 AM
Eightfuns's Avatar
Default Re: trying to find out cel (BoostdRex)
ugh but it is an obd 1 ecu
Old Aug 10, 2005 | 10:38 AM
Suck my DX's Avatar
u sure that its obd1?
Old Aug 10, 2005 | 10:40 AM
Eightfuns's Avatar
Default Re: trying to find out cel (Suck my DX)
it a 1988 stock engine/ecu, i thought obd2 came out in 96
Old Aug 10, 2005 | 10:57 AM
BoostdRex's Avatar
Stock wiring for Civic: 1988-1991 are OBD0; 1992-1995 are OBD1; 1996-2000 are OBD2.
Correct me if I am wrong on 1992-2000, but I know for certain 1988-1991 are OBD0. They have no jumper. Just the flashing light on the ECU, flashes the same way the CEL works when you jump it in a newer Civic that's OBD1/2..
Old Aug 10, 2005 | 11:01 AM
Eightfuns's Avatar
right on so i took a look and the red light just keeps flashing like 30 or 40 times really slow, am i suposed to do more than just turn the ignition on?
Old Aug 10, 2005 | 11:03 AM
BoostdRex's Avatar
No, just turn on the ignition (don't need to start the car): Check for breaks in between flashes. Like 2 quick flashes, then a break, then 2 quick flashes and a break. That would be a code 2. So-on- and so-forth...
If it's just slow, 1-flash patterns, maybe that's a code 1. Which would be Oxygen content. Check oxygen sensor and replace if necessary.
Here is a Cel guide specifically for CRX's (join our group too! ) :
http://www.crxownersclub.com/f...ic=62
Modified by BoostdRex at 12:30 PM 8/10/2005
ConanDan
Jan 28, 2008 08:57 AM
integg93
Sep 26, 2005 10:13 PM
rhemu1
Aug 6, 2004 08:09 AM
Fraggle
Dec 8, 2003 06:43 PM
