Cons of running this ECU?
Old Aug 10, 2005 | 05:14 AM
Liquidgsr's Avatar
Default Cons of running this ECU?
I lost my OBD1 P72 so im looking for a cheap stock ECU to use and came across a OBD2B. Im thinking of running this in my 94 GSR with a conversion harness. What would be the cons of running this, other than the fact that a OBD1 ecu would be better for mods. Also Im going to run my car stock but is the OBD2B chippable?
Old Aug 10, 2005 | 06:35 AM
drdisco69's Avatar
Default Re: Cons of running this ECU? (Liquidgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr &raquo;</TD></TR><TR><TD CLASS="quote">is the OBD2B chippable?</TD></TR></TABLE>
It is, but you'll be sorry. The hardware is around $400-$600. You're really better off spending $130 and getting the OBD1 P72. The OBD2 has a crank fluctuation sensor, so you'll have to replace your oil pump... Then you have to put up with the **** engine managment. OBD2 will set a code for anything it feels like. After you buy the ecu, wiring harness, crap to make it run, etc, you could have had 3 OBD1 ecus.
Old Aug 10, 2005 | 07:03 AM
Liquidgsr's Avatar
Default Re: Cons of running this ECU? (drdisco69)
I see..God wish i didn't loose my Stock ecu.
nothing_shocking
Engine Management and Tuning
Dec 1, 2010 04:00 PM
thanh4o8
May 16, 2008 11:10 AM
E.
Apr 21, 2008 08:40 AM
big-cat
26
Oct 19, 2006 11:14 AM
2.2 teg
Oct 20, 2005 08:21 AM
