Defi-Link...anyone with experience?
whats going on. it took me awhile to figure out where to post this, but i figured the type r guys track (not just the straight line) their car more than other honda/acura owners, and i was hoping someone could give some personal experience.
i currently am running a defi boost and oil pressure gauge in my gsr, both are great - very accurate and reliable.
im debating on getting an egt and oil temp gauge...but remembered reading about the Defi-Link.
a lot of companies have similar units out right now, but was wondering if anyone had anything to say about the Defi's. Defi does make great monitoring equipment, and it seems very accurate, simple, and easy to use; plus itll clean up the interior a bit.
all help is appreciated
I have the Defi control unit, Defi Link, fuel press and oil press. Boost and Oil temp BF gauges. they work really well. By far one of the the best on the market. highly recomend plus the daisy chain makes it so easy to install.
great...im also looking at the VSD...now it says you can link it to the defi link control unit...and i guess it displays each monitoring by user-selectable mode, as in speedo, tach, and say oil temp. then you can change to water temp?
now..i was reading on the defi site, that you can read boost with the defi link display...is this correct?
elpiar
Oct 26, 2005 11:21 AM
