chipped p28 problems
Old Aug 9, 2005 | 06:18 PM
hialeahzbg's Avatar
Default chipped p28 problems
i have an ls vtec on a 96 dx..... b4 when i had 96 wire harness i had a jumper with a chipped p28....now i did a 00 si wire harness so im runnin a stock si ecu now....i got a jumper for the 00 now and plugged up the same p28 and it idles all weird now...b4 it was perfect idled perfect and everything... y not its all messed up?
Old Aug 10, 2005 | 05:59 PM
ant813's Avatar
Wiring is different for a 1996-1998 and 1999-2000 model. So might just have to redo the wiring. Its just a bit different.
Ant
Old Aug 10, 2005 | 09:11 PM
hialeahzbg's Avatar
no i have 99-00 si harness now.... i did the conversion.....
Old Aug 10, 2005 | 10:28 PM
Sinner's Avatar
Default Re: chipped p28 problems (hialeahzbg)
ls vtec has low compression while a 00 si has simi-high compression. are you using the same tune? could be the chip.
Nick
Old Aug 11, 2005 | 08:41 AM
civic-4-ges's Avatar
Default Re: chipped p28 problems (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">ls vtec has low compression while a 00 si has simi-high compression. are you using the same tune? could be the chip.
Nick</TD></TR></TABLE>
Note: Same P28, different wiring harness...would the ecu program change from that???
Are you throwing any codes???
The only major difference I can see are, the seconday o2 sensor is no longer part of your harness (Should not be an issue, but may affect your o2 heater), and the IACV/Vtec wiring, which I assume you added in on your previous harness
Old Aug 11, 2005 | 09:03 AM
hialeahzbg's Avatar
my ls vtec is built for high compression 2....i have b16 parts in my ls block...i put the p28 on 1 more time and it worked fine maybe the car just had 2 get used 2 the new ecu
doublezerohatch
Jul 17, 2013 07:18 AM
HondaBondMan
Oct 26, 2004 07:24 AM
B20zvtecek
Jan 22, 2003 07:52 PM
ScrapinSi
Oct 15, 2002 02:52 PM
Chuji
Aug 23, 2002 07:03 AM
