need help with my A/C compressor...
hey my ac compressor makes a
funny *** noise ...like squeek noise hella loud too..
well does anyone know how to fix that..
it only makes it when its idleing or low RPMs..
i checked it out and it seems like the a/c gets stuck
or held back....i was told it was the bearing....but not sure...
and also i was told it could be that it needs oil like with the
freon or something....any suggestions or help ...please reply back
Thanks
Thanks
Both times when my compression was making any kind of noise the compression went shortly after, the first time it squeeling only at idle and low rpms like yours and the compressor locked up shortly after. The second time it sounded like a supercharged car, and the bearing went bad with sparks flying around my compressor clutch. And oil will not save you before any of these incidents occur.
i opted for a new one with warranty rather spend 250-300 bucks once than spending 75 twice and having to remove it twice............................................
then i dropped a b18b like 4 month later ac gone
my compressor avaeraged around $80 used. A new one will run you at least $285. And they only warranty it if you have proof that it was professionally installed. removing it is not that hard. It's just more difficult if you still have a factory crossmember.
the soL that could
Aug 15, 2011 02:54 PM
