Rear Axle
Old Aug 9, 2005 | 07:18 AM
JohnWayne's Avatar
Default Rear Axle
My rear wheel wobbles slightly when driving. I have jacked the car up and the wheel is on tight and secure. I was told this may be caused by worn bearings on the rear axle.
Can anyone help me diagnose the problem and what I need to do to fix it?
Thanks
Old Aug 9, 2005 | 07:21 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Well for one thing, there is no rear axle.
However bearings are a possibilty. Raise the car off the ground and spin the wheel and see if you can see it wobble. Then take the wheel off and spin the hub and see if you can pinpoint which part is causing the wobbling.
Old Aug 9, 2005 | 07:33 AM
JohnWayne's Avatar
Default Re: Rear Axle (JohnWayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Well for one thing, there is no rear axle.
However bearings are a possibilty. Raise the car off the ground and spin the wheel and see if you can see it wobble. Then take the wheel off and spin the hub and see if you can pinpoint which part is causing the wobbling.</TD></TR></TABLE>
Alright thanks alot, what is there instead of an axle? excuse my ignorance.
Old Aug 9, 2005 | 07:36 AM
Community Builder
Honda rear suspensions consists of a trailing arm, which holds the hub, a lower control arm and upper link (kind of a psuedo-upper control arm, but not really) at the rear of the trailing arm, and a toe control link at the front of the trailing arm.
Rear axles are only used on RWD cars, or on FWD cars that have a solid beam axle in the back. Hondas made after 1988 have independent rear suspension, so no axles.
desi01
Dec 18, 2009 04:40 AM
HOODLOVER
Oct 26, 2008 07:24 AM
ITRDC2R
Jun 1, 2007 05:43 AM
xlusiveracer
Mar 15, 2006 01:25 PM
servion
Sep 5, 2003 11:33 AM
