will a stock p28 work with a gm 3 bar
Old Aug 9, 2005 | 06:39 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default will a stock p28 work with a gm 3 bar
like the topic says, i dont want to take my eg through inspection on the sniffer test with 750's i want to take it through with stock injectors and stock p28.
will it work? if not i think i can tweak the 750's but i think it will be easier to swap out. ill post this in the FI forum as well for the stand alone guys.
Old Aug 9, 2005 | 06:54 AM
boosted k20's Avatar
Default Re: will a stock p28 work with a gm 3 bar (boostedcivicsir)
u cant run a 3-bar on a Stock ECU. it will most likly trip CEL and run horrible.
if ur car is tuned really good with the 750cc then u should be able to pass inspection
u can also wire in the stock map sensor in parallel to the 3-bar wires, but cut the signal wire going to the 3-bar and put it on the stock map sensor. then u will need to run the stock ecu and u can put the stock injectors back on
another thing, r ur 750cc injectors high or low impedance. if they r low u will need to bypass the resistor box
Old Aug 9, 2005 | 07:23 AM
Mr. Badwrench
Default Re: will a stock p28 work with a gm 3 bar (boosted k20)
i do run the wires in parallel now my car was the first one i did and didnt do that. i will try to get it to pass with the cat n/a with the 750's. thanks for the reply.
jetspeedz
Jul 20, 2009 12:21 PM
B16CRXT
Engine Management and Tuning
Nov 21, 2008 02:16 AM
lch
Apr 17, 2007 07:27 AM
M.A.R.C.
Mar 20, 2006 07:36 AM
boostedcivicsir
Aug 9, 2005 07:24 AM
