grinding noise
Old Aug 8, 2005 | 10:08 PM
teewhy55's Avatar
Default grinding noise
just did new shocks, lower ball joints, and front axles, but noticed when i was driving a wierd grinding/clunking sound is coming from the left front wheel. it is not continuos, but i can feel it when it happens. with me changin so much it is hard for me to pinpoint the problem. thanks for any help
Old Aug 8, 2005 | 10:23 PM
NikoZai's Avatar
Default Re: grinding noise (teewhy55)
is it only when you turn the wheel while driving? especially while accelerating?
Old Aug 8, 2005 | 10:29 PM
teewhy55's Avatar
seems to happen while going straight at speeds above 30 mph
could heating the axle nut with a torch ruin the bearing?
or maybe something axle related? im stumped
Old Aug 8, 2005 | 10:58 PM
teewhy55's Avatar
ttt need any ideas
Old Aug 9, 2005 | 05:52 AM
Duane_in_Japan's Avatar
Simple, if it didnt do it before you touched it, then you fucked it up gus, you beat it up and broke it didnt you, tell the truth.
Old Aug 9, 2005 | 07:10 AM
b18_crx's Avatar
Default Re: grinding noise (Duane_in_Japan)
haha something similar happened to me after camber kit was installed, axles and upper A arm.......th uper a arm kept hitting getting stuck inside frame !
Old Aug 16, 2005 | 12:47 PM
teewhy55's Avatar
Default Re: grinding noise (b18_crx)
i have narrowed it down to 2 things: upper arm bushing being shot. Or possibly upper arm hitting frame because the new koni yellows lowered it even more. One thing i did notice more than ever is that when i drive over bumps or gutters the wheels feel loose and you can hear them make a wobbly sound. I thought the new Lower balljoints would have fixed this but, no it didnt. I think new upper arms are needed and wondering if theres an upper arm that has camber correcting balljoint, while i am at it. I know vision does but man thats expensive for upper arm. TIA
Old Aug 27, 2005 | 11:05 AM
Tyson's Avatar
is it a metal, tinny, scratching sound? kinda irregular but never seems to go away?
Civichatch2k
11
Aug 7, 2006 05:43 PM
Civichatch2k
Suspension & Brakes
Jul 30, 2006 09:34 PM
NoGreenCard
Sep 9, 2005 07:53 AM
rudeman85
Nov 4, 2004 01:19 PM
cvc323
Aug 13, 2003 01:07 PM
