Check engine light
iwas out joy riding, going a pretty quick. . . and as I came into second gear, i got more than the little tire chirp, my tires actually began to spin, for a moment then I caught traction and right after that my check engine light came on, i pulled over to a gas station and checked under the hood everything appeared to be fine when i hopped back into the car and started it back up the light was off, i drove for another 10 minutes(much slower). It came on again, when I got home I turned the car off then back on an dthe light was off again, any ideas on what could be causing this?
Needs to be About 20% Cooler
pull down the passenger carpit. u'll see a red blinking light. turn the ignition on and count the blinks and thats the code.
Didn't check the code on the ECU I used to wires (not sure what they are called) I was told if i connect those togethor that the it would show the code on the odometer by flashing the check engine light. I did that And got 2 slow blinks then 2 fast ones. i checked my ECU and don't see any lights at all. Iam running OBD-1 and my ECU is a p30.
The light went off againa dn this time it stayed off. I drove it for about 45 minutes and it didn't come back on, any idea what could have caused this?
i'll double check that, th elast question I have is about the 2 wires that I have that are supposed to tel lme codes. i was tol dby th eperson who sold me the car that if i hold these two wires togethor (blue & orange comnig from hrness going into ECU) that it will tell me codes. I did that and it gave me the 2 slow and the 2 fast, does that sound right and does it work the same way that people's little red light on their ECU? Because I don't appear to have that light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote"> it's a little green plug near the VTEC solonioid. </TD></TR></TABLE>
make sure u got a good ground to it and that the wire (blue i think) is a good conection back to the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M15 »</TD></TR><TR><TD CLASS="quote"> any idea what could have caused this?</TD></TR></TABLE>
Have you checked your oil level?
Okay it looks like it was the VTECpressure switch. there are 2 wires coming from it a red one ( I think) and a black one, I'm assuming that the black one is a ground and i was wondering did it matter where i grounded it? or if I'm wrong where does that wire go?
If you managed to heat up your engine to 205 degrees on a hot day, your oil probably thinned out and it sensed a drop in oil pressure. This is common in the summer. Use a thicker oil durring the hot months.
Okay it turned out it was the ground after all, and i have it grounded all gangsta right now but I'll getit soldered and to a beter spot later, most important part is that my Check engine light is off. Thanx All.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote">code 22 is (if i remimber right) is VTEC oil switch. it's a little green plug near the VTEC solonioid. </TD></TR></TABLE>
Yeah, code 22 is Oil pressure switch, I had that code come on last week with the CEL. It turned out to be that the other end of that switch wire wasn't grounded at all
So I grounded the wire, and reset the ECU and the were no codes and a CEL.
UpstateCivic
Jun 7, 2003 12:27 PM
type Gendy
Apr 21, 2003 04:48 PM
