1/8 NPT male to BNPT fiting, where to find (oil pressure guage install)
Im installing an oil pressure guage (mechanical) and im removing the oil sensor on the back of the block and puting the supply line for the guage there, Where can I find a male (BNPT) fitting on one side that size that goes into an 1/8 NPT male fitting on the other side? Also I was thinking that I should coil the soft copper like that do on brake lines so if the motor moves there wont be any tension. Will this copper break from all of the vibration?
Thanks in advance, Matt
Those brass ones are weak bs. Go to http://www.mcmastercarr.com, click on pipe fittings, they have them in stainless steel for like $6--the quality is amazing.
Is this the one I need?
Part Number: 4092K11 $6.50 Each
ANSI Specification
ANSI B31.1 and ANSI B31.3
ISO Specification
ISO 7/1, BS21
Shape
Adapter
Adapter Type
Adapter (Male x Female)
Pipe Size
1/8"
Material
316 Stainless Steel
Pipe to Pipe Connection
BSPT Male x NPT Female
Maximum Pressure (psi)
6100
Specifications Met
American National Standards Institute (ANSI) and International Organization for Standardization (ISO)
ANSI Specification
ISO Specification
ISO 7/1, BS21
Shape
Adapter
Adapter Type
Pipe Size
1/8"
Material
316 Stainless Steel
6100
Specifications Met
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote">Those brass ones are weak bs. Go to http://www.mcmastercarr.com, click on pipe fittings, they have them in stainless steel for like $6--the quality is amazing.</TD></TR></TABLE>
Brass is fine enough, as long as you know how to torque them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smash fascism »</TD></TR><TR><TD CLASS="quote">Is this the one I need?
ANSI Specification
ISO Specification
ISO 7/1, BS21
Shape
Adapter
Adapter Type
Pipe Size
1/8"
Material
316 Stainless Steel
6100
Specifications Met
</TD></TR></TABLE> Yup, thats the one, by the way http://www.mcmastercarr.com is the best place to go for plumbing like that--its such a good place. Once you see this stainless fitting (it is SO well made--especially for the money--I think z10 wanted $21 for a similar fitting) you will see that brass is GARBAGE for an oil pressure fitting.
ANSI Specification
ISO Specification
ISO 7/1, BS21
Shape
Adapter
Adapter Type
Pipe Size
1/8"
Material
316 Stainless Steel
6100
Specifications Met
I know how to torque them..the ones you are talking about (sunpro) really are crap. If you must have a brass fitting http://www.mcmastercarr.com (again) has very high quality brass fittings. They have sheet metal, titanium bolts, aluminum bolts, carbon fiber--basically anything having to do with machinery...
RACEPAK
Jun 4, 2006 02:34 PM
NeXtLeVeL_TyPe_R
Oct 2, 2001 09:50 PM
