help with installing a tack
Old Feb 21, 2002 | 10:57 AM
-=TWITCH=-'s Avatar
Default help with installing a tach
please tell every step i need to install a tach thanks i want to make sure i can do it before i buy a 150 tach thanks
[Modified by -=TWITCH=-, 8:07 PM 2/21/2002]
[Modified by -=TWITCH=-, 11:43 PM 2/21/2002]
Old Feb 21, 2002 | 10:59 AM
Spade's Avatar
Default Re: help with installing a tack (-=TWITCH=-)
Why?
Oh and it's Tach.....short for tachometer.
Old Feb 21, 2002 | 11:07 AM
-=TWITCH=-'s Avatar
Default Re: help with installing a tack (Spade)
sorry tach cause i have never done it before
Old Feb 21, 2002 | 11:09 AM
Spade's Avatar
Sorry I should have explained my why?
Why do you want to purchase a 150.00 tach?
What car is it going in?
There are better ways to spend your money and still be able to monitor your RPM's
I would look into a AFC with the capability to monitor RPMs 250 bux.
[Modified by Spade, 12:09 PM 2/21/2002]
[Modified by Spade, 12:15 PM 2/21/2002]
Old Feb 21, 2002 | 12:48 PM
-=TWITCH=-'s Avatar
please just tell me how to install it dang
Old Feb 21, 2002 | 02:42 PM
-=TWITCH=-'s Avatar
where do i tap coil ecu please explain this like your explaining it to a newb cause i am thanks
[Modified by -=TWITCH=-, 12:20 AM 2/22/2002]
Old Feb 22, 2002 | 01:22 PM
Giuseppe's Avatar
how many places do u have to ask this question...?!?!
i think we've given extensive answers to your 'problem'
Old Feb 22, 2002 | 04:10 PM
salbaje's Avatar
Default Re: help with installing a tach (-=TWITCH=-)
here you go
red wire to switched power when you turn ignition to on position
black to ground
green wire to negative terminal on distributor
white to be tapped in where your illumination light goes on so that your tach will have light
B18c1_EG
Apr 8, 2003 04:21 PM
RuKKus
Sep 28, 2002 09:30 AM
A-LEX
Aug 6, 2002 11:48 AM
