guye i am really confuse i need some help....
ok i have a 94 ls an i am gettin a jdm type r swap from Hmotorsonline
wut would be some of the things i might need for the swap like idk my car is
OBD-1 and the jdm itr is OBD-2 wut do i have to do ? isnt the jdm ecu diff do i need like a harness conversion or something plz help.
Modified by 94IntegraLs04 at 11:36 PM 8/8/2005
.wut would be some of the things i might need for the swap like idk my car is
get and usdm obd 2 integra wire harness and plug that bitch in. You will have to add vtec wires if you don't get a gsr or a type r, then get an adapter harness to plug the ecu into your car, or chip a P28 or P30 to type r spec. gl
the JDM engine wiring harnesses are backwards and won't fit a USDM car, u can use your Ls hareness, but you will have to add wires for vtec and knock. Also idk if the LS are pre wired for vtec from the shock tower to the ECU. search and you will find most of your answers
Kirk@SyndromeAuto
Dec 13, 2006 05:24 PM
