Which parts to use for Honda Day!!!
Old Aug 8, 2005 | 04:15 PM
B16aEGx2's Avatar
Default Which parts to use for Honda Day!!!
I have a stock jdm b16a in an eg hatch, I/H/E, with test pipe, vafc [ not too sure how to use it to its full potential ] , fpr and 255 pump.
I have a Revhard IM, aem cam gears, and skunk 2 stage 2 cams [no retainers or springs though] not yet installed from another car that i just bought.
My question is should i even bother with the IM, aren't there IM's for high hp?
I'm probably going to put on the gears and wait on the cams until i get the springs and retainers.
Also any hints or suggestions on vafc set up. I'm trying to pull some good #'s for the 13th. Any suggestions would be help full.
Old Aug 8, 2005 | 08:15 PM
boosted k20's Avatar
Default Re: Which parts to use for Honda Day!!! (Chinaon20s)
no suggestions for VAFC if u dont have a wideband or access to a dyno with an a/f ratio module.
i'll also be head n out to E-town for honda-day! cant wait to run my slow *** car
Old Aug 9, 2005 | 06:54 AM
B16aEGx2's Avatar
Default Re: Which parts to use for Honda Day!!! (boosted k20)
Revhard intake manifold, stock motor??????????
Old Aug 9, 2005 | 11:42 AM
JerseySiPOS's Avatar
Use an ITR manifold and tune for the most area under the curve from 6000-9000 rpms with the Skunk2 stage 2 cams. And put a stock fuel pump back in.
Old Aug 9, 2005 | 11:59 AM
Default Re: Which parts to use for Honda Day!!! (JerseySiPOS)
u can use the 255 pump, but just turn the fuel pressure down to the stock setting.
u need some tunign if u put parts on the car. get a Wide band or hit up the dyno
Old Aug 9, 2005 | 01:07 PM
B16aEGx2's Avatar
I have the Revhard IM laying around though, i don't really have the money for the itr. should I just sell it or is it worth using?
Where's a good place to go for tuning around central jersey, i'm in monmouth county?
crxrocket
Aug 3, 2007 12:01 PM
toda_eg6
Feb 23, 2005 10:03 PM
Creative
Aug 2, 2004 01:29 AM
G3gsr
Feb 2, 2003 12:38 PM
ActiveAero
Dec 27, 2002 10:53 AM
