Nother Headlight Problem....
Old Aug 8, 2005 | 04:11 PM
Threads's Avatar
Default Nother Headlight Problem....
My passenger headlight only works when I put the hazards on, then turn the lights on. Sometimes I would have to turn my radio off. It recently stopped coming on even if i did this. The high beams work perfect, but the low beams are a no go. All wiring, that was done by me, is good.
I think this is a power problem. I did do some soldering, but everything has been checked. I am thinking it is where the low beam power wire(s) ends up. So what I am looking for is where the low beam power wire(s) connects to. Fuse Box? ECU?
All help is appreciated thanks.
Old Aug 8, 2005 | 04:15 PM
robbie_R(eg6)'s Avatar
thats a werid problem i suggest just tapping this headlight to the other one so they both turn on at the same time, altho they might be a little bit dimmer than before depends on how much this bothers you
Old Aug 8, 2005 | 04:17 PM
Threads's Avatar
Default Re: (robbie_R(eg6))
Interesting, but if that doesnt work, I know its my product, but like I said it was working just recently. I never thought about tapping it. I thought they were tapped into each other already.
BTW: All fuses look good.
Old Aug 8, 2005 | 04:22 PM
im pretty sure they run of separate circuits either way one is turning on fine even just tap the low beam wire would probably do it, and which product were u talking about?
Old Aug 8, 2005 | 04:26 PM
Threads's Avatar
Techone HID kit......good stuff
Old Aug 8, 2005 | 05:00 PM
Threads's Avatar
Default Re: (Threads)
all other suggestions are appreciated
Old Aug 8, 2005 | 05:16 PM
Evanmb44's Avatar
you said all fuses "look" good. a fuse can still be blown even if it looks good. check the fuses with a ohmmeter to be sure
Old Aug 8, 2005 | 05:19 PM
startin to sound like its the HIDs possibly the igniter
DAprojectTuRtle
Honda Civic (2001 - 2005)
Apr 16, 2012 02:41 PM
powerwagon340
Dec 24, 2008 01:07 PM
Sic_DA_Nine
Lighting
Apr 2, 2008 02:37 PM
Uncle Ben's
Jul 8, 2007 12:08 PM
cincispeedemon
Feb 20, 2004 02:16 PM
