upper control arm help
I just installed my axle and gained axcess trough the upper control arm , but how i cant seem to put the castle nut back on( connecting the a arm with the upper control arm ) and now all it does is spins with the ball join since the ball join is no longer wedged in, any help to get the castle nut back in whould be great .
Well, aside from the fact I NEVER disconnect ball joints to change an axle, I have changed knuckles and ran into this problem. What I do, is take a file and score the shaft coming out of the ball joint up pretty good. I then take a rat tail style file and score the hole in the top of the knuckly up pretty good also. This will allow the shaft to bite into the hole and keep it from spinning.
Air also helps to put some serious speed on the castle nut and get it tight. Don't forget to lube up those threads also.
ill do something like what he said if i really need to.
ill try impact gun first tho, if thats available. the impact helps thread it in without moving the balljoint.
but nowadays, i just chase the threads on the nut and the balljoint. i bought some 10x1.25 and 12x1.25 tap and die. makes everything much easier instead of fighting it. i used to just buy new castle nuts, but rethreading it makes it as good as new. ive saved a few other bolts and parts as well.
xChrizcrozzx
38
Dec 9, 2016 10:34 AM
unclematt
12
Jun 2, 2016 04:31 AM
