AEBS Manifold INstall
Old Aug 8, 2005 | 09:49 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default AEBS Manifold INstall
Ok well i installed an AEBS Mani and Skunk 2 68mm throttle body on my B16. Well started it up and it idles out and all. But whenever i try to give it gas it stalls out. Im trying to pull a TPS of my hatch to put on my B16 but its riveted on there. Anyway in the mean time im trying to figure out if anyone else has any suggestions.
Old Aug 8, 2005 | 09:56 AM
Supernatural's Avatar
Default Re: AEBS Manifold INstall (Mattb16teg)
slice the rivet enough so that u can unscrew it with a flat head screw driver.....and are u sure u didnt reverse the map and tps sensors?
Old Aug 8, 2005 | 11:03 AM
GOLDBERG's Avatar
Default Re: AEBS Manifold INstall (SUPERNATURAL)
a lil off but what did yall do bout the peice of crap threadded holes on the aebs manifold for the fuel rail studs
Old Aug 8, 2005 | 12:39 PM
v-6 hatch's Avatar
ur hatch huh?
Old Aug 8, 2005 | 07:21 PM
moto1320's Avatar
Default Re: AEBS Manifold INstall (v-6 hatch)
Well it sounds like you have your plugs swapped, buuuut....why do you want to try another TPS. If you don't have a voltmeter to dial it in or more importantly check the one you have with, then it isn't going to help.
Old Aug 9, 2005 | 06:51 PM
b17eghatch's Avatar
it may sound crazy but are you sure you put the t-body gasket is on right my buddys car did the same thing
TopGear_
Aug 18, 2009 11:15 AM
DC209
10
Dec 9, 2007 04:11 AM
94vtirozguy
Oct 3, 2006 05:57 AM
miataguy
Aug 1, 2004 11:32 AM
Kevedge
Feb 21, 2004 08:12 AM
