Lock for shifter mechanism
Old Aug 8, 2005 | 09:03 AM
MestizoRacer310's Avatar
Default Lock for shifter mechanism
I saw this on accordwagonclub.com........
I need to know where I can get that lock for the shift lever! Anyone know?
Old Aug 8, 2005 | 09:25 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Lock for shifter mechanism (MestizoRacer310)
I don't know who makes them but from the way it looks, would it be possible for someone to unscrew the shift **** pry up on that loop a bit and pop the shifter out of the loop/lock?
Good idea but not sure how affective it would be if the **** was removed. I mean what it looks to be mounted to isn't real strong, you could probably get it to flex enough without damaging much if anything to remove the shifter from the lock if the **** was out of the way.
I don't know, thats just my $.02, I could be way off since I've never seen one in person.
Old Aug 8, 2005 | 03:25 PM
Eddiebx's Avatar
haha what a coincidence, thats one of my customers' car.
its a multi-lock, you can probably get it at any car audio shop. imo i hate it, cuz its a pain in the *** to get the center console off with that on
Old Aug 8, 2005 | 03:27 PM
Eddiebx's Avatar
Default Re: Lock for shifter mechanism (TouringAccord)
oh that thing isn't going anywhere, **** is like 1/8" steel bolted to the frame down below. and theres no way in hell your gonna pry it up and slip the shift lever through. i had a hell of a time getting the damn console off to work on the **** last time.
Old Aug 8, 2005 | 05:59 PM
H-T Order of Merit
Default Re: (Eddiebx)
oh, so it actually bolts to the frame below the center console.
Old Aug 8, 2005 | 10:40 PM
Default Re: Lock for shifter mechanism (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">oh that thing isn't going anywhere, **** is like 1/8" steel bolted to the frame down below. and theres no way in hell your gonna pry it up and slip the shift lever through. i had a hell of a time getting the damn console off to work on the **** last time.</TD></TR></TABLE>
I was kind of thinking what TouringAccord said about being able to pry up but that sounds real good. But just how bad does it add to working on things that require removal of the centre console?
Old Aug 8, 2005 | 11:15 PM
Eddiebx's Avatar
it gets a bit annoying cuz say if you want to get that center console out, you really need to like bend her out of the way and squeeze it out.
though i guess you could just go under the car and unbolt it, but i never bothered trying that before.
but its definitely pretty sturdy that it can't be just pryed off.
Toe_Knee
Jun 26, 2008 02:25 PM
kevinm30
Honda Civic (2006 - 2015)
Aug 7, 2006 06:42 PM
japhonda
12
Jun 24, 2005 12:40 PM
TSAngry
Feb 19, 2004 09:12 PM
fw190bvi
Jan 7, 2004 10:06 PM
