Stumble at 10in/hg
Old Aug 8, 2005 | 06:04 AM
StrangerWitCandy's Avatar
Default Stumble at 10in/hg
yeah, what the title says, my car sometimes stumbles as i tip-in the gas, but its ALWAYS right at 10in/hg as read by my boost gauge.
Setup (and possible coulprits)
RC 550 injectors
used waldbro 255 HP
Uberdata, with basicly just a basemap, but the A/F's are just about perfect so i havent tuned it much yet, and its running with closed loop disabled since closed loop sucks with UD
theres a Wideband in the car
its also turbocharged, but it did it before i installed the turbo. It seems like it started after i installed the injecors, but im not sure.
anyone got any ideas? could it be the spacing of the injectors against the intake mani? because when i changed them there were plastic spacers there along with the o-rings (im assuming they put them in whenever the skunk2 mani was installed for fuel rail fitment), and i dident need the spacers to make it fit, so i took them out.
Old Aug 8, 2005 | 02:44 PM
Chiovnidca's Avatar
Default Re: Stumble at 10in/hg (StrangerWitCandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StrangerWitCandy &raquo;</TD></TR><TR><TD CLASS="quote">yeah, what the title says, my car sometimes stumbles as i tip-in the gas, </TD></TR></TABLE>
Is it going lean? Does ud have a tip-in adjustment like hondata?
Old Aug 9, 2005 | 07:16 AM
Default Re: Stumble at 10in/hg (Chiovnidca)
i dont see it going lean... my datalogging isnt hooked up right now so i dont know for sure, but ive tried upping the fuel values at that spot, and it hasnt helped.
uberdata has a tip-in adjustment, but its not as much at tip in, its just whenever i cross 10in/hg... i can tip in at any other level of vacuum or boost and its fine, its just when i cross 10in/hg. and i can hold it right at 10in/hg and it works fine too, so i dont think my fuel setting right there is off... im really confused. mabey ill try crome and see if it solves the problem.
Old Aug 9, 2005 | 12:53 PM
up
Old Aug 11, 2005 | 05:48 AM
up again... someone has to have an idea
Old Aug 13, 2005 | 07:28 AM
i guess noone has any ideas.
Old Aug 13, 2005 | 08:04 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StrangerWitCandy &raquo;</TD></TR><TR><TD CLASS="quote">i guess noone has any ideas.</TD></TR></TABLE>
Have you tried messing with the ignition timing in that area? (just an idea)
Old Aug 13, 2005 | 09:19 AM
mmuller's Avatar
Mad Scientist
did you rescale the maps for the new injectors?
Old Aug 13, 2005 | 12:41 PM
Default Re: Stumble at 10in/hg (mmuller)
i did rescale the maps... i hadent thought about the timing though, should i try advancing or retarding it?
thanks for the help!
Old Aug 13, 2005 | 05:54 PM
mmuller's Avatar
Mad Scientist
why dont you post timing and fuel maps? it would be a lot easier to troubleshoot
Old Aug 15, 2005 | 06:28 AM
sounds like a good idea... but do you know any site that will host .bins?
atarigamer01
Oct 30, 2008 06:39 PM
eg6T
Dec 19, 2005 05:42 AM
racingfan
Jan 20, 2005 11:37 PM
HuskerHybrid
May 29, 2004 07:00 PM
B00ST2nR
Mar 15, 2004 06:51 PM
