gear swapping
Old Aug 8, 2005 | 04:55 AM
4gZC's Avatar
Default gear swapping
ive been looking all over the boards for a how-to on tranny gear swapping. i have an extra si trans that has crappy gears & want to swap them out for the zc gears that i am buying. i just want to get a heads up or how-to on the swapping. doesnt seem that easy.
Old Aug 8, 2005 | 08:29 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: gear swapping (4gZC)
it's not easy till you do it several times. at first it's very intimidating...more than likely to **** it up unless you have a helms and/or someone who knows what they are doing to assist you.
Old Aug 8, 2005 | 10:57 PM
4gZC's Avatar
Default Re: gear swapping (not so civic)
so its not as simples as taking out a screw here & there and just swapping it to the other trans? i found a zc trans for 2hundo shipped, and i have an extra si tranny to work with. i just cant find a how-to or anyone that can help me out swapping the gears & i am definatly going to do it myself beacause that is what i do.
Old Aug 9, 2005 | 08:25 AM
well it sounds like you rather do the work yourself. i'm all for people learning and not being scared to dissect and reassemble something like an engine or tranny. it just takes the mentality, which you have, and i would suggest a helms book and just study through the manual tranny pages before and during. taking it apart and putting back together is actually easy as long as you have the parts inside right. the hard part is keeping everything inside in their respective and correct placement. it's easy to install a gear or something upside down...this is all it takes to throw everything off and cause binding. you have to pay serious attention to everything inside. go for it and just pm me if you have any questions whatsoever or tbone, who i believe knows alot about sohc trannies and compatibilities.
Old Aug 9, 2005 | 01:30 PM
4gZC's Avatar
thanks for the heads up man. i will go get a book & study the parts. i also have a 4spd trans im going to mess with first, just to learn the basics. then move to the si/zc. if there are any write ups or tips on this, please let me know. thanks
JOE BD-0
Jan 27, 2008 07:49 PM
LoneStarCRX
Mar 4, 2007 12:24 PM
B18C5-EH2
44
Jul 6, 2004 04:54 PM
redzcstandardhatch
10
Nov 24, 2003 06:07 AM
GirlyGS-R
Feb 20, 2003 09:06 PM
