Civic Questions
Old Aug 8, 2005 | 12:15 AM
vms2005's Avatar
Default Civic Questions
I have a 96 civic ex that a 1.6l w/vtec. I wondering what type of engine (d16 or what ever) I have and also where I should start for getting more horsepower out of my engine. I have a header and short ram intake. I'm looking into buying a intake manifold with AEM fuel rail and perforamce injuectors. What else would I need for fuel system. Any suggestions on brands or parts.
Which is better a short ram intake or cold air intake?
I am open for suggestions. I have never built a tuner before, only old schools so I don't know to much about this subject.
Old Aug 8, 2005 | 01:14 AM
92ehatch's Avatar
Default Re: Civic Questions (vms2005)
timing belt cover will have your engine number on it
Old Aug 8, 2005 | 04:58 AM
sicky's Avatar
grammer nawzi
Default Re: Civic Questions (93egsedan)
Don't **** your money down the drain like that, if you are going to do anything to it, turbo it. I/H/E are going to do **** to that motor. Wasting that kind of money on fuel system parts are just going to do waste gas. Use that money and get a turbo, or a new motor.
Old Aug 8, 2005 | 05:24 AM
pdiggitydogg's Avatar
You have a d16y8
You do not need a fuel rail or injectors - you will not get any power out of either (stock rail is good to over 400hp). The best thing you could do at this point is exhuast or a cam. If you want to ditch the intake and header you just shelled out for, piece together/buy a turbo kit or swap in a different larger engine.
Please use the search feature and read the forum rules:
https://honda-tech.com/zerothread?id=990205
Rule 1.C.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Posting general modification threads in '92-00 Civic / Del Sol is not allowed. This includes threads like "What should I do to my car next?" or "I have $$$ what should I buy?" Please do a search, as there are many threads on the subject that exist in the archives.</TD></TR></TABLE>
Welcome to Honda-Tech
Old Aug 8, 2005 | 05:54 AM
96 SOHC VTEC's Avatar
Unfornutely bolt-ons really don't do much on that motor. I had I/E on my D16Y8 and it wasn't a huge difference. You could also try swapping out the final drive for shorter gearing and get a lightened flywheel. Those would also help with acceleration as the EX has tall gearing.
Old Aug 8, 2005 | 07:36 AM
b16brandon's Avatar
Default Re: Civic Questions (96 SOHC VTEC)
swap that d16 for a b16 than turbo it
iampeetor
Jul 3, 2004 07:37 AM
Jeager521
Jul 22, 2003 06:05 PM
hondacivic4g
Jul 16, 2002 12:35 PM
