check engine light with vafc?
Old Aug 7, 2005 | 09:15 PM
Dasani's Avatar
Default check engine light with vafc?
One day one of my friends wanted to put a relay into my mass air flow sensor, but when we turned on my car the light came on so i told him to put it back the way it was, but now the the light is still on and i'm concerned something else is wrong, so i went to advance auto parts to get it checked, but because of the vafc, it won't read..how can i check it, because i'm running nitrous and i want to make sure it's not detonating my internals?
Old Aug 7, 2005 | 09:21 PM
komat's Avatar
Default Re: check engine light with vafc? (Dasani)
i have a vafc on my b16a
i can check my codes fine
have you try resetting your ecu?
Old Aug 7, 2005 | 09:26 PM
Dasani's Avatar
wouldn't that reset the vafc as well?
Old Aug 7, 2005 | 09:41 PM
Dasani's Avatar
Default Re: (Dasani)
bump
Old Aug 7, 2005 | 11:00 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasani &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't that reset the vafc as well?</TD></TR></TABLE>
Not to sound likea jackass or anything but the VAFC keeps its memory without power, hence everytime you take your key out it returns back to how you left it. Resetting the ECU is just a matter of unplugging your battery for 20 seconds or so. The CEL won't usually go away by itself right away, even if the problem is fixed so thats why you need to reset it.
And the VAFC doesn't hinder the ECU from being read at all. Are you sure it's installed correctly? I've seen so many times that the wrong wires are tapped when its installed, etc.
Old Aug 8, 2005 | 09:03 AM
Dasani's Avatar
Default Re: (EKcivicEX)
it was professionaly installed and dyno tuned by ride revolution. I wasn't to sure about everything with the vafc. Thats all the help i needed,
thanks
dzzrunnin411
Jan 20, 2007 10:35 AM
EK_BackHatch
12
Mar 4, 2004 02:05 AM
Patch
Dec 10, 2003 04:09 PM
IgniteTeg
Apr 30, 2002 10:56 PM
SonicDark
Aug 5, 2001 10:00 PM
