Very high idle
Old Aug 7, 2005 | 06:57 PM
vtec94civic's Avatar
Default Very high idle
Alright my car was in the body shop after i got into an accident and after a few days of driving my car when i got it back i noticed that the car started to idle unusually high. when i start the car up in the morning it idles at like 3k rpm and when its warm it idles at like 1.8-2k rpm. i thougt it was my iac valve so i pulled it, cleaned, swapped it out and even blocked it off to see if it was the problem and its still the same. i noticed that when i took off the intake and i plugged up the hole, in the opening on the left of the the tb before the throttle plate, that the it begins to idle perfectly normal. if anyone has any input or had a similar problem please let me know.
btw the tps, timing and all sensors are hooked up and seems to be working properly. also there are no vacuum leaks or any leaks in the intake mani or tb gasket.
Old Aug 7, 2005 | 07:03 PM
95dxhatch's Avatar
theres a screw on your throttle body that adjust idle. cant remember if screwing in lowers idle or if screwing out lowers. turn it one way and see what happens...... and is your throttle cable kinked anywhere at all?
Old Aug 7, 2005 | 07:39 PM
already tried adjust that screw. its almost all the way in.
Old Aug 9, 2005 | 03:35 PM
poblem isolved it was the fitv. i removed the tb and i noticed that there was something rattling int there so i remove the 2 8mm screw that hold the cover on and screwed in the white plastic piece back in. everything is fine now.
Iloveyourhonda92
Apr 11, 2015 07:46 PM
michaelsej1
18
Feb 21, 2011 07:13 AM
mad21kid
Feb 18, 2008 12:52 PM
b16a3delsol
Aug 15, 2007 09:29 AM
SilverSellout
12
Feb 27, 2004 12:48 PM
