weird stuff... please look!!!
Old Aug 7, 2005 | 04:19 PM
shreddinryguy's Avatar
Default weird stuff... please look!!!
Ok well i got done putting my motor in and everything seemed fine and it was running good. So i went to take a for a drive and it had no power. The car just would not move. No matter how much gas i gave it it just would increase speed slow but constant. Now i am throwing a couple codes and this is where it gets kinda werid. One of the codes that I am throwing is code 19 which is the shift lock soleniod but that code is for only autos. Also I am throwing the IAT code but I replaced and check all that and it is all good. Also I have no knock sensor but yet am not throwing the knock sensor code. Now I thougth it was just my timing b/c i was told if it was off a tooth this would happen but my timing is good. Coudl this just be a bad ecu??? I dont see what else it could be and since im getting some werid codes it makes sense to me. Any suggestions are appreciated.
Old Aug 7, 2005 | 05:03 PM
VALET dude's Avatar
Default Re: weird stuff... please look!!! (shreddinryguy)
hmmm...it almost sounds like you got an auto ECU. try and switch/replace it and see what happens.
-John
Old Aug 7, 2005 | 11:27 PM
RedEj8's Avatar
Default Re: weird stuff... please look!!! (JDMallmotaEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallmotaEG &raquo;</TD></TR><TR><TD CLASS="quote">hmmm...it almost sounds like you got an auto ECU. try and switch/replace it and see what happens.
-John</TD></TR></TABLE>
Thatd be my guess
Old Aug 7, 2005 | 11:40 PM
FalkenSiR's Avatar
Default Re: weird stuff... please look!!! (reddohcvtec)
Did you have to do any wiring or repinning?
Old Aug 7, 2005 | 11:46 PM
Skinflute22's Avatar
lol yeah my buddy has similar probs and he had an auto ECU accidently... get a different ECU and be sure its Manual
Old Aug 8, 2005 | 12:15 AM
Syner-G-Racing LLC's Avatar
what ecu do you have?
heres how to find out for sure if you want to bust it open....
Old Aug 8, 2005 | 03:04 AM
Default Re: weird stuff... please look!!! (Syner-G-Racing)
im starting to think that it is an auto ecu but when i put my freinds jdm p72 5 speed in there it still had no power. Would i be able to drive it still with an auto ecu or do I have to get a different one right now. And what would be making me loose all this power.
jchrm80
Jun 20, 2007 08:51 PM
93sidelsolvtec
Jan 22, 2007 03:50 PM
sir2sol
Apr 1, 2005 04:55 PM
UNDER PRESSURE
Feb 4, 2003 01:07 PM
Shft@9GSR
Feb 10, 2002 12:04 AM
