b16a sir2 help asap
Old Aug 7, 2005 | 03:22 PM
keaps206's Avatar
Default b16a sir2 help asap
i have a 95 civic hatch with a jdm sir2 and somthing is wrong with it it starts up fine and then when it gets to normal temp when i come to a stop sign or just slow down my revs go donw and then it dies out i checked my spark plugs and its kinda light beige and my car sometimes puts out white smoke i kinda think its my head gasket or running lean but not sure can someone help me out please
Old Aug 7, 2005 | 03:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: b16a sir2 help asap (keaps206)
try cleaning out the ports on the throttle body. sometimes the iac valve can stick causing a low idle issue. if that doesnt cure it, it may ultimately need replacement.
Old Aug 7, 2005 | 05:29 PM
keaps206's Avatar
ok ill try that out
Old Aug 7, 2005 | 05:40 PM
revhard_si's Avatar
YEAH IT MIGHT BE THE IDLE SENSOR OR RELATED TO IT...OR SOME WIRES CROSSING..GOOD LUCK
Old Aug 7, 2005 | 06:25 PM
siregcivic's Avatar
check your cam timing... my friend got a sir2 b16a and when he put it in when cold it would be fine but as soon as it warmed up it would sputter then take off.... the intake cam was off a tooth or 2
Old Aug 8, 2005 | 08:34 PM
revhard_si's Avatar
Yeah he's right...try it n get us an update
clkupai
Engine Management and Tuning
Nov 19, 2012 11:35 AM
nates97coupe
Nov 4, 2011 11:14 PM
jayshf
Sep 17, 2009 08:10 PM
ULTRA911
Feb 15, 2003 12:19 PM
