Suspension & Brakes Theory, alignment, spring rates....
SWAYS ON 97 DX
Old Aug 6, 2005 | 10:23 PM
vietnameeh's Avatar
Default SWAYS ON 97 DX
i wanted to get some sways for my 97 dx wondering....
what companies make thicker sways...and/or could i use factory sways
i read something about having to make endlinks or drill of some sort.
im running adjustable sleevs and adj. tokicos ... front camber kit....front strut,, and rear lower tie
Old Aug 6, 2005 | 10:26 PM
kaiba's Avatar
Default Re: SWAYS ON 97 DX (vietnameeh)
Since you have a 97, the rear lca is ready for swaybar. What size are you looking for. You can get stock 99-00 Si, 94-00 integra which i think both are 19mm. Or you can go 22mm or 23mm type r, but then you will need the beak kit.
Old Aug 6, 2005 | 10:28 PM
vietnameeh's Avatar
i was thinking about the 99-00 si sways... are there any items i would need with this?
Old Aug 6, 2005 | 10:52 PM
iaredavid's Avatar
just make sure the si sway bar comes with endlinks and brackets, and you'll be good.
like kaiba said, you could also use the integra rear sway bars, gsr being 14mm, itr at 22mm and jdm-itr at 23mm. btw, the si sway is 13mm. the integra rear sway bars need to use the si endlinks, though. if you do get something over 14mm, you should probably get a subframe reinforcemcent kits so you dont tear out the subframe. check out a-spec-racing.com or beaksproducts.com if you're interested.
something you should probably know is that a rear sway without a front will get you some oversteer, not sure how much, since i've never tried a car with only the rear sway. if you want a front sway, you'll have to use the front lca and sway off the 99-00 si or 96-00 ex. the front sways off the integra tend to be a bit big, and they might hit the shift linkage or cat. not too sure.
good luck, i'm about to do the front and rear swaybars to my ek hatch soon.
Modified by iaredavid at 10:26 AM 8/7/2005
Old Aug 7, 2005 | 06:11 PM
vietnameeh's Avatar
how much do guys think si sways should cost?
Old Aug 7, 2005 | 06:25 PM
EK k kay's Avatar
Default Re: (vietnameeh)
Around $80. It's not the si say bar that costs a lot, it's the endlinks that make it expensive.
Old Aug 7, 2005 | 06:57 PM
vietnameeh's Avatar
arite THX guys
everythign should bolt up right ...?
Old Aug 7, 2005 | 07:43 PM
iaredavid's Avatar
yeah, the rear sway is pretty easy to install
just position the sway bar in, then loosely mount the brackets. attach the endlinks, tighten the endlinks, then tighten the mounting brackets.
http://www.hazone.com/hsirearsway.htm for pictures
Old Aug 8, 2005 | 01:10 PM
KtHaNxBai's Avatar
anyone know where i can get a front sway for my 97 dx coupe???
the whole swap.
and how much should it be?
Old Aug 13, 2005 | 09:11 PM
vietnameeh's Avatar
questions how can i tell if its a SI sway bar?....serial numbers or anythign this guy is giving me a good price and he says its brand new...smells fishy... but is there a way i can tell or a serial number?
Old Aug 18, 2005 | 02:24 PM
iaredavid's Avatar
none really, an si is a 13mm in diameter, just bring a ruler or a micrometer. aslo, make sure its a 99-00 si, and not an 01+.
how much is this 'good price'.
you gotta remember the mounting hardware too- brackets and endlinks.
the p/n's are:
P/N 52321-S04-003 - left rear endlink
P/N 52320-S04-003 - right rear endlink
P/N 52300-S52-A01 - swaybar
the endlinks are about 45 each from oe honda, and the sway bar about 60, all new- so 150 if you get it from like hondaautomotiveparts.com
Old Aug 18, 2005 | 02:59 PM
EK k kay's Avatar
Default Re: (iaredavid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iaredavid &raquo;</TD></TR><TR><TD CLASS="quote">none really, an si is a 13mm in diameter, just bring a ruler or a micrometer. aslo, make sure its a 99-00 si, and not an 01+.
the p/n's are:
the endlinks are about 45 each from oe honda, and the sway bar about 60, all new- so 150 if you get it from like hondaautomotiveparts.com</TD></TR></TABLE>
You also need the d brackets and bushings.
Old Aug 18, 2005 | 03:53 PM
vietnameeh's Avatar
he wants 200 for both front and rear with hardware
Old Aug 18, 2005 | 04:02 PM
iaredavid's Avatar
if new, thats damn good. if used, thats a bit high. for the front, is he including the front lca? cuz non ex/si will need ex or si lca.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">You also need the d brackets and bushings.</TD></TR></TABLE>
u dont need to go oem honda for brackets and bushings- energy suspension is perfect.
black00ta
18
Oct 13, 2015 03:51 PM
Thirty-Nine
Oct 16, 2006 07:25 AM
B18C1SI
May 5, 2006 02:24 AM
KtHaNxBai
May 20, 2005 03:36 PM
wdskuk
Sep 21, 2003 08:17 PM
