Transmission jerk question
Old Aug 6, 2005 | 10:41 AM
97akwerd's Avatar
Default Transmission jerk question
My car done this for months, and I just wanted to see if anyone knew what it was...
Whenever I shift from Park to Reverse or Park to D3 etc, the car waits a second then has a notiable jerk. My transmission was rebuilt a little over a year ago, but the shifts are pretty good. Is there any reason it does this? It's very noticable when i go into Reverse almost seems like a clunk, could this be my motor mounts?
Old Aug 6, 2005 | 11:20 AM
BB6racer's Avatar
sounds like your transmission wasn't rebuilt properly. my accord had that problem before it was rebuilt, and now it's fine. doesn't sound like a mount problem though.
Old Aug 6, 2005 | 12:30 PM
KaoSyN's Avatar
Default Re: Transmission jerk question (97akwerd)
My only suggestion would be to check and maybe change the tranny oil, and also maybe start saving some side money for your next tranny lol
Also, although theres probably a negative side to this I put more oil than whats recommended, It helps mine out a bit.
Old Aug 6, 2005 | 12:34 PM
phateless's Avatar
good excuse to swap it to a manual
Old Aug 6, 2005 | 01:00 PM
97akwerd's Avatar
Default Re: Transmission jerk question (KaoSyN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaoSyN &raquo;</TD></TR><TR><TD CLASS="quote">My only suggestion would be to check and maybe change the tranny oil, and also maybe start saving some side money for your next tranny lol
Also, although theres probably a negative side to this I put more oil than whats recommended, It helps mine out a bit.</TD></TR></TABLE>
I change tranny fluid every 3k miles Kinda overkill but can't hurt soo why not?
I think more is bad for trannys because with more it can cool as efficiently...that's what i've heard.
when you check yours, how do you check it COLD, or after a drive?
Old Aug 6, 2005 | 01:01 PM
97akwerd's Avatar
I also put in a tranny cooler, don't know if it helps though...
98bucket
Sep 7, 2010 04:18 AM
Coolero
Jan 10, 2009 11:14 PM
boost and bass
Oct 26, 2008 10:15 AM
joshuaaaronalpert
Jun 10, 2005 07:12 PM
a_new_honda_owner
Mar 17, 2004 05:21 AM
