squeeking in the motor
Old Aug 6, 2005 | 08:34 AM
SHhh__VTEC's Avatar
Default squeeking in the motor
When I start my car, everything seems ok. When the motor warms up, it start squeeking. It sounds like it's coming from the intake manifold area. Sounds like a bird. It mainly does it when i'm in gear, and when I turn off the engine(after it's been warmed up). When I turn off the engine, it squaks really loud and just cuts off. The squaking doesn't fade away, it all of a sudden stops when i turn off the motor. Would anybody have any idea what this is. I have NO idea what it is and it's fustrating b/c i can't fix it.
Old Aug 6, 2005 | 10:51 AM
onefastrx7turbo's Avatar
Default Re: squeeking in the motor (SHhh__VTEC)
check your belts
neil
Old Aug 6, 2005 | 10:54 AM
SHhh__VTEC's Avatar
It's not the belts. I checked those. It sounds like a whisle, bird, **** like that. It has to be something with air.
Old Aug 6, 2005 | 11:09 AM
BB6racer's Avatar
so does the noise get louder when you push the gas pedal, or does it get louder as the revs climb up?
Old Aug 6, 2005 | 11:37 AM
SHhh__VTEC's Avatar
Actually, the noise happens in gear most of the time. Like, I'll be in 5th gear cruising, it'll just squak squak squak constantly. When I push the gas, it stops, but when I let off, it starts again. It doesn't get any louder, it's just constantly there.
It has to do something with heat. When the motor is cool, nothing happens. When it's warmed up, it makes the bird noise.
Old Aug 6, 2005 | 04:06 PM
GST-RIDER 95's Avatar
I had the same thing happen to me in my 96 Type-s.
The noise started at about 10% throttle and vanished at about 60-70% through WOT.
Very disturbing sound to hear.
I traced this particular whistleing sound to the shift linkage at the transmission end.
Both the washers that go between the white plastic spacers and the bushings were missing that explained in my case why I could only hear the noise when I was in gear and not when I would rev my engine at idle.
I found two slim washers that permited me to be able to drive the pin real snug trough the hole.
Old Aug 6, 2005 | 04:53 PM
SHhh__VTEC's Avatar
I dont see anything missing on my tranny shift linkage. It's weird. It also makes the noise when I turn off the engine too, while it's in nuetral. How can that make noise??
CScivic22
Mar 28, 2009 04:14 PM
Haruspex
Feb 27, 2007 02:59 PM
rivoe302er
Feb 19, 2007 05:43 AM
redrelease
10
Aug 15, 2006 05:40 PM
jdmjunkieXL
Jul 2, 2006 08:03 AM
