.mov file of my idle issue. Has anyone ever had idle like this?
Old Aug 6, 2005 | 04:01 AM
brokenojoke's Avatar
Default .mov file of my idle issue. Has anyone ever had idle like this?
Someone else said it sounds like valves are too tight.
Sorry for the crappy audio, but here is the 'JIST" of things.
Motor is 1'st gen B16a with CTR slugs,cams, rev valvetrain, port and polish, and mugen head gasket. It only has idle time and no road time yet. I'm using Hondata s200 and switched all the wiring to obd1 from obd0. I am throwing no codes and I have the logger to ensure me of that.
When I first start the motor is runs fine, but after a minute or so it start to sound like it's choking. Just like it's lopy from a huge cam, but it's only CTR cams. Then, if I give it anywhere from 5% to 10% throttle, it magnifies the problem/sound. But if I give it a quick 25% throttle or more, it stops, until it gets back to an idle.
http://www.we-todd-did-racing....5NTQx
Old Aug 6, 2005 | 08:13 AM
90_crx_si's Avatar
Default Re: .mov file of my idle issue. Has anyone ever had idle like this? (brokenojoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brokenojoke &raquo;</TD></TR><TR><TD CLASS="quote">Someone else said it sounds like valves are too tight.
Sounds like a tuning issue....but i'm no expert.
Old Aug 6, 2005 | 09:03 AM
Suck my DX's Avatar
Default Re: .mov file of my idle issue. Has anyone ever had idle like this? (90_crx_si)
tow it to ur trusted shop and get that thing tuned...that thing is gonna be one hot motor...
Old Aug 6, 2005 | 09:27 AM
blo2k1's Avatar
Default Re: .mov file of my idle issue. Has anyone ever had idle like this? (Suck my DX)
i had the same problem with a swap i did on a b16 put on a aftermarket throttle body and it made the same funky idle so i got some gasket maker at napa and then it ran great
Old Aug 6, 2005 | 09:50 AM
RaysBoomBoomLude's Avatar
Default Re: .mov file of my idle issue. Has anyone ever had idle like this? (blo2k1)
it sounds really weird. Does that mean its running Lean?
It sounds like a miss. Did you do anything with your coolent? a buble could be on your ICV.
Old Aug 6, 2005 | 07:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blo2k1 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem with a swap i did on a b16 put on a aftermarket throttle body and it made the same funky idle so i got some gasket maker at napa and then it ran great </TD></TR></TABLE>
I'm using an aftermarket t/b gasket. I'll throw a type r one on the next chance I get and see if that helps.... Thanks. If it still does the same thing, I'll use some hondabond and see if that seals it up.
Old Aug 6, 2005 | 08:48 PM
gnar kill's Avatar
you know I am sure you have already tried these but timing, spark (plugs, wires, maybe pull the plugs out just to see you they look, dizzy) and maybe a vacuum leak
Old Aug 7, 2005 | 02:26 AM
UNKNOWN_MEMBER's Avatar
Default Re: .mov file of my idle issue. Has anyone ever had idle like this? (gnar kill)
Did you guys just swap the motor in? just saw the video, and i had the same problem. Problem was i got the knock sensor mixed up with the iavc. Check to see if the plug you got on the iacv is a 2plug wire.
Old Aug 8, 2005 | 02:44 PM
Default Re: .mov file of my idle issue. Has anyone ever had idle like this? (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">Did you guys just swap the motor in? just saw the video, and i had the same problem. Problem was i got the knock sensor mixed up with the iavc. Check to see if the plug you got on the iacv is a 2plug wire.</TD></TR></TABLE>
That may actually be it. I'll check that tonight.
Old Aug 9, 2005 | 06:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brokenojoke &raquo;</TD></TR><TR><TD CLASS="quote">That may actually be it. I'll check that tonight.</TD></TR></TABLE>
Nope, my knock sensor is a single wire. Damn, the search continues.
I know it has to be something stupid, it always is. Any more ideas?
Old Aug 10, 2005 | 10:34 PM
did you check it? It's something with your iacv, it's not closing.
JDM_SOHC
27
May 13, 2013 05:09 PM
faSHOwidIT
Mar 25, 2005 02:07 AM
slimbo
May 16, 2004 10:57 PM
MoFo
Feb 11, 2003 09:37 AM
