Couple of quick Questions
Old Aug 5, 2005 | 05:02 PM
poop32145432's Avatar
Default Couple of quick Questions
I'm rebuilding a stock B16 VTEC head and I need some torque specs on the following items:
1. 10mm & 12mm Cam cap bolts
2. Cam gear bolts
3. ARP head studs to the block
4. ARP Stud nut torques
For the engine it is a stock B20B:
1. Crank Pulley Bolt
2. Flywheel Bolts
3. Pressure Plate Bolts
4. Timing belt tensioner bolt
Thank you guys very much, your help will be greatly appreciated.
Old Aug 5, 2005 | 08:41 PM
Default Re: Couple of quick Questions (mp7235)
Anyone?
Old Aug 6, 2005 | 09:45 AM
TurboCoop's Avatar
I'll go get my service manual in a minute and tell you. I think the ARP head bolts to the block are just like 10lbs
Old Aug 6, 2005 | 02:10 PM
TurboCoop's Avatar
Default Re: Couple of quick Questions (TurboCoop)
10mm cam caps(8)-7.2 lbs
12mm cam caps(20)-20 lbs
You will have to read ARP's directions for them, it is a multi-step process.
Crank pulley is 130 lbs
I dont know the rest of them, sorry.
DC_RaceR
Feb 14, 2006 04:58 PM
notsure
Jun 18, 2004 10:57 PM
dabomb
Oct 5, 2003 07:05 PM
b20b
Mar 3, 2002 11:46 AM
