did i blow my turbo seals on my turbo already?(sc63)
ok it's been about a week since i had my car back and today the car felt differnt so i pop the hood and a bolt from manifold to turbo backed out,so while inspecting everything else i notice oil in the compressor side of the turbo(a light suite with a swirl) then i notice oil leaking from the bolts where you clock the turbo. i wipe it off cleaned every thing up screw back the bolt that came loose from the manifold and now no oil in the compressor but still a light seapage from the bolts where you clock the turbo.
another thing is that it's only been a week with fresh oil in the car and already the oil is black and thin that when i pull the dip stick it's like water it just runs right off
could this be my problem?
i tought i was to do a oil change every 1000 miles it's only about 400 miles so far.
someone help me out here please?
Modified by 11seclude at 8:22 PM 8/5/2005
it depends if the oil was backing up, then no it will be fine, but if ur return line is good and u see oil there then most likely they could be leaking
did you have an oil restrictor? I heard you need no because the oil pressure from the motor is way too much for most turbos
