Hondata/Uberdata users: Is your ECU install "clean" after tuning?
Old Aug 5, 2005 | 08:55 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Hondata/Uberdata users: Is your ECU install "clean" after tuning?
For those of us who have cars that weren't OBD-I from the factory, whether it be OBD-II or OBD-0...is your ECU install with the conversion harness CLEAN? Meaning, you are easily able to tuck the wires, and fit in the ECU and make it look factory?
Does anyone have before/after pics of your ECU/harness setup while tuning?
As in, pics of your ECU opened up and on the floor, with all the wires running and everything - and then an after pic of everything put away?
I just don't want any wires hanging around after the tuning's done.
Sorry if my title/description is weird.
Old Aug 5, 2005 | 09:04 AM
urbansi's Avatar
Default Re: Hondata/Uberdata users: Is your ECU install "clean" after tuning? (boostincoupe)
my ecu slighty sticks out from the kick panel. and the wires do hang a little low, but it still looks clean. i guess if you really try to make everything as hidden as possible you could but i have to take my car to emissions soon and it needs to come out so its not as clean as it could be
Old Aug 5, 2005 | 09:27 AM
mike1114's Avatar
Default Re: Hondata/Uberdata users: Is your ECU install "clean" after tuning? (urbansi)
On my EG, everything fits back exactly the way it was factory. There is a gold plate that holds the wires all nice and neat that goes over the ecu from the factory, everything bolts back exactly the way it was.
I also had a 97 coupe that also had a obdII to obdI converter and all fit back perfect still.
pawan
Engine Management and Tuning
Nov 30, 2010 05:51 AM
huge230
Sep 3, 2005 08:03 AM
Simple
37
Nov 7, 2004 07:59 PM
sshaikh01
26
Mar 28, 2003 07:49 PM
