Which pistons for ls/vtec
Old Aug 5, 2005 | 08:24 AM
spoonzdelsol's Avatar
Default Which pistons for ls/vtec
okay i have searched and no info on pistons if i wanted to turbo a ls/vtec which i am wanting to do so any help would be nice i am using a b18b block and b16a2 head
Old Aug 5, 2005 | 09:19 AM
superbeastcrx's Avatar
Default Re: Which pistons for ls/vtec (spoonzdelsol)
run the ls rods and pistons, because they are able to hold to 300hp
Old Aug 5, 2005 | 12:11 PM
Default Re: Which pistons for ls/vtec (superbeastcrx)
thanks for the info
Old Aug 5, 2005 | 02:46 PM
elrandeeto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superbeastcrx &raquo;</TD></TR><TR><TD CLASS="quote">run the ls rods and pistons, because they are able to hold to 300hp</TD></TR></TABLE>
i agree , i was gonna say p30's till i saw the boost part stock for under 300hp
Old Aug 6, 2005 | 06:48 AM
thanks agian so what if i want to go over 300 then what should i use?
Old Aug 6, 2005 | 07:08 AM
Default Re: (spoonzdelsol)
eagle rods and pistons. they can handle up to 600 hp! and you can buy them from http://Summitracing.com
Old Aug 6, 2005 | 10:43 AM
SiR Inspired ED7's Avatar
Default Re: (superbeastcrx)
high compression JE pistons any good for Ls/Vtec?
Old Aug 6, 2005 | 11:40 AM
Malgerus's Avatar
Default Re: (88 Crx Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">high compression JE pistons any good for Ls/Vtec?</TD></TR></TABLE>
N/A, yes.
Boosted, no.
Old Aug 6, 2005 | 12:05 PM
Default Re: (Mr. S)
ok All Motor&gt; Boost
would the je piston (high comp)s be able to handle at least some amount of boost? i've heard it's been done but what results are we going to be looking at? thanks
Old Aug 6, 2005 | 12:48 PM
JDM Panda's Avatar
the most compression i would... even think about useing is maybe 10:1..Thats only because i seen a ls/vtec turbo run 11 flat in a full interior 99 si lol
Old Aug 6, 2005 | 01:11 PM
Bunger's Avatar
Default Re: (JDM Panda)
Running higher comp with boost will make your tuning window smaller, if you don't plan on running a lot of boost, you can get away with run higher comp.
Old Aug 6, 2005 | 06:50 PM
Default Re: (Bunger)
high comp pistons and a turbo dont mix well, this setup could cause you to throw a rod, blow head gaskets all the time!
Old Aug 7, 2005 | 08:13 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superbeastcrx &raquo;</TD></TR><TR><TD CLASS="quote">high comp pistons and a turbo dont mix well, this setup could cause you to throw a rod, blow head gaskets all the time!</TD></TR></TABLE>
It would make crazy power if it was tuned right, but there is zero room for error... so i wouldn't do it.
I would run 9:1-10:1 for boost.
Jdmsolutions
10
Feb 25, 2008 08:30 PM
ys1civicsi
Feb 4, 2008 06:44 AM
92integra-R
Jan 17, 2007 01:52 PM
the.hamburglar
Dec 28, 2005 03:46 PM
OEMJDM
Jun 30, 2002 01:01 PM
