integra dash swap problems
im in the process of swapping in a teg dash into my 92 hatch. i think ive got most things working but ive come to a standstill.
i cant get my signals to work
its a 95 dash using teg harness. i used the grey civic fuse box plug and just matched up the wires from the teg harness, i dont have a diagram for either but most colors matched so i just spliced em with eachother. but i have 1 wire left
yellow with a blue stripe
HELP
diagrams would be ill
HELP
Search or Use this thread
https://honda-tech.com/zerothread?id=1053318
Also make sure your hazard button is hooked up and working.
Should be yel/blk. Splice that to the yel wire on the big green plug.
This will help too: https://honda-tech.com/zerothread?id=1211255
Ok, I forgot the functions of each wire. But, look behind your cluster and find the pin that is plugged into the circuit for the speedo. Trace the circuit back to the speedo. Know what I mean? It's like a maze. Find out what color wire that is, then trace it back on the harness and make sure it's plugged in.
Lemme know.
Lemme know.
streetracerof06
Jul 3, 2006 02:21 PM
streetracerof06
Jun 28, 2006 03:33 PM
ATX45
Apr 30, 2006 09:14 PM
shivic
Aug 2, 2005 06:03 PM
Midwest Auto Salon
Sep 15, 2004 08:27 PM
