Beaks EG Quick-Swap kit. Quick Help plesae.
Vehicle Info:
1994 Honda Civic Hatch back DX
OEM Shocks
HP Racing Coilovers
I really want this kit and was wondering what all I needed for this to work and fit right?
Do I need ITR rear LCAs?
If I get rear ITR LCAs do I have to have rear ITR shocks for them to work?
Will this setup put my subframe at risk (HP Racing Coilovers)?
I plan on ditching the OEM shocks and coils within the year for Omni Power full coilovers or something equal to or above that quality. Thanks in Advance!
OEM Shocks
HP Racing Coilovers
All you need is a set of rear lower control arms that have the threaded mounting hole for the sway bar. I have a set from a DC2 integra (non type r), they are direct bolt in. And so are LCAs from EG sedan ex, and del sols. Or you can get aftermarket ones like Omni. Don't get the ITR ones, very different from many DC2/EG components, and will not bolt up with ease. But I recommend that you get two new bolts for them because the stock bolts that mount the strut to the LCA are locking and have a tendency to shear off.
The G2 Racer
Feb 10, 2003 12:31 PM
