Unique mini me problem (auto tranny/ high idle)
Old Aug 4, 2005 | 08:37 PM
needaimport's Avatar
Default Unique mini me problem (auto tranny/ high idle)
i did a min me on an auto dx.
the idle seems to be high when im in park, but once i get into drive and reverse, the idle is normal. is that a problem?
we tightened the idle adjustment screw, spray brake cleaner to look for leaks, and manually checked the TB.
the gasket we uised was new and we added some sealant.
anyone know if this is a problem and what i should check for?
Modified by needaimport at 10:06 PM 8/4/2005
Old Aug 4, 2005 | 08:38 PM
Deemeetree's Avatar
Electrician
Are all vacuum lines connected? Are all sensors connected? Have you tried adjusting the idle screw?
MikeNice's Avatar
Default Re: Unique mini me problem (needaimport)
Check throttle cable, vacuum lines etc.
Old Aug 4, 2005 | 08:39 PM
all of those were checked.
Old Aug 5, 2005 | 08:46 AM
anything else?
Old Aug 5, 2005 | 08:50 AM
Default Re: (needaimport)
also, we are running the z6 manifold but with the d15b7 injectorss.... is that a problem? because the d16z6 injectors dont fit, and when we made it fit, they werewnt firing
Old Aug 5, 2005 | 12:50 PM
bump please
Old Aug 5, 2005 | 01:42 PM
Civic4less's Avatar
is your IACV 2 or 3 wire?
crxguy406
Sep 10, 2015 03:56 AM
1kleenef
Sep 29, 2007 07:39 AM
jdm4drSi
Apr 6, 2007 08:19 AM
ILoveJDM.
Dec 25, 2005 11:34 AM
kihun_cha
20
Sep 17, 2004 03:18 PM
