which Cometic gasket are you using?
Old Aug 4, 2005 | 10:35 AM
H-series LX's Avatar
Default which Cometic gasket are you using?
On a b16 motor w/ctr cams and all the bolt-ons and stuff, what size head gasket are yaw'll using for all-motor app.
Im thinking around 82mm?
Please lend me your thoughts.
Old Aug 4, 2005 | 10:46 AM
91civicEX's Avatar
Default Re: which Cometic gasket are you using? (H-series LX)
i think it depends what your bore is. someone quick whats the stock bore on a b16?
Old Aug 4, 2005 | 10:55 AM
Default Re: which Cometic gasket are you using? (91civicEX)
of course stock bore, I aint going to the block.
Old Aug 4, 2005 | 11:56 AM
PURPLETERROR aka BIGMATT's Avatar
Why would you use an 82 mm headgasket on a stock 81mm bore b16? Stick with and oem gasket from honda.
Old Aug 4, 2005 | 12:40 PM
no no the thickness i meant
.030?
hondaex99
Mar 4, 2010 06:22 AM
Honda4life777
Oct 9, 2009 08:36 PM
SiR_Injected
Oct 24, 2007 09:52 AM
avividmemory
Nov 14, 2002 05:32 AM
vspec12
Apr 12, 2002 04:50 PM
