what head gasket do i need?
Old Nov 12, 2002 | 05:49 PM
avividmemory's Avatar
Default what head gasket do i need?
this may sound like a stupid question,
but i have a b16 sleeved to 83mm, is a b16 head gasket going to work for that, or am i going to need a crv one or what
figured i should ask before i buy the wrong thing
Old Nov 13, 2002 | 10:05 AM
highbrid's Avatar
Default Re: what head gasket do i need? (SpoolinLS)
u need a custom one
call up golden eagle, they make good ones
[Modified by highbrid, 7:06 PM 11/13/2002]
Old Nov 13, 2002 | 10:06 PM
Default Re: what head gasket do i need? (highbrid)
ok thanks
Old Nov 14, 2002 | 04:13 AM
PWRVTEC's Avatar
Just get a CRV headgasket. If you ever measure the stock B16 gasket with the bore of the cylinder you will notice about .40 mm of a difference. So overall the headgasket bore is a bit bigger. so A CRV gasket is 84mm which should be perfect.
Old Nov 14, 2002 | 05:32 AM
tony1's Avatar
Default Re: what head gasket do i need? (PWRVTEC)
Except for the fact that you will have a huge oil leak from where the oil feeds the vtec through the block. You have to use a vtec gasket
boomslang
Sep 30, 2002 04:51 PM
boomslang
Sep 30, 2002 04:37 PM
vspec12
Apr 12, 2002 04:50 PM
