fuel pump
Old Aug 4, 2005 | 08:57 AM
blueR87's Avatar
Default fuel pump
ok another question. if u hear the fuel pump, does it mean its working good? i hear it when i turn the key. i try starting the ef and its just turning over but no start. after a while i smell fuel. thanks
Old Aug 4, 2005 | 09:37 AM
IronOutlawz's Avatar
Default Re: fuel pump (blueR87)
You might not have spark if you can hear the pump and smell fuel. Have you checked for spark yet?
Old Aug 4, 2005 | 09:50 AM
blueR87's Avatar
is there a way i can check it without spending money? thanks
Old Aug 4, 2005 | 08:57 PM
Default Re: (blueR87)
yea, pull one of the spark plug wires off of the dizzy and turn the car over to see if there is spark.
Old Aug 5, 2005 | 01:10 AM
Magick211's Avatar
Default Re: (IronOutlawz)
Or you can pull one of the spark plugs out and stick it back in the wire then hold the plug really close to one of the valve cover bolts and check for spark while someont else is cranking the motor
nkerr09
Honda Motorcycles
Aug 3, 2017 04:24 PM
philztheone
Nov 5, 2014 10:28 AM
dan617
Feb 3, 2009 11:18 AM
trav143
11
Oct 8, 2008 10:58 AM
kuks24
Aug 29, 2008 12:26 PM
