b20 head on ls block
Old Aug 4, 2005 | 01:26 AM
Eg6_LsR's Avatar
Default b20 head on ls block
can i put a b20 head on a b18a1 ls block? if so what head bolts and head gasket do i use? thanks.
Old Aug 4, 2005 | 01:34 AM
Eg6_LsR's Avatar
i need a real quick answer please.
Old Aug 5, 2005 | 06:08 PM
Eg6_LsR's Avatar
Default Re: b20 head on ls block (Eg6_LsR)
i just need to know which head gasket to use.
someone please help.
Old Aug 5, 2005 | 06:14 PM
ALLMOTA92EG's Avatar
you wouldnt want to because it will lower the compression and the head bolts just use the ls ones with a ls headgasket.
Old Aug 5, 2005 | 06:16 PM
FaceTuned's Avatar
isnt the b20 cmbstn,chmber alot bigger than a ls the ls is what 81mm,and the b20 is 84mm is that right will it work
Old Aug 5, 2005 | 08:07 PM
Eg6_LsR's Avatar
Default Re: (jdmhatchness)
i wouldnt, but its just extra parts i have laying around. thanks for the reply. will it be alright if i used the b20 head gasket??
Old Aug 6, 2005 | 05:24 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatchness &raquo;</TD></TR><TR><TD CLASS="quote">isnt the b20 cmbstn,chmber alot bigger than a ls the ls is what 81mm,and the b20 is 84mm is that right will it work</TD></TR></TABLE>
most b20 heads are the exact same as the ls motor, the p8r head(b20) has chambers are 84. if the b20 head is the 81mm you use the ls head gasket.
Old Aug 6, 2005 | 05:46 PM
Eg6_LsR's Avatar
Default Re: (projectTeG)
ok i got the head from my friend's b20b motor that he bought from a shop. i just found out that the head says p75.. isnt that from a ls. it has a b20 manifold and everything, but the head looks like it came from a b18b. i dont really care because i know that the ls head is better, but why did the shop do that? since its a ls head and i got a ls block arent they both 81mm so i should use a ls head gasket right?? if so can i still use the b20 head gasket?
Old Aug 6, 2005 | 05:52 PM
projectTeG's Avatar
yes p75 is a ls head so is a p75....they are the heads on the newer b18bs. you use the b18(ls) head gasket.
Old Aug 6, 2005 | 05:54 PM
Eg6_LsR's Avatar
ok thanks
low&slowef
Mar 5, 2011 03:02 PM
Sr420Det
Nov 10, 2010 07:49 AM
Damills
Mar 10, 2009 11:32 AM
B20BHatch
Aug 12, 2004 08:40 PM
